Thermostat And TrueIAQ Wiring. - HVAC - DIY Chatroom Home Improvement Forum
Old 01-21-2009, 08:53 PM   #1
Thermostat and TrueIAQ wiring.
Robert Shaw page six; http://www.icca.invensys.com/manuals.../110-1044B.pdf
TrueIAQ page 12; https://customer.honeywell.com/techl...0s/69-2072.pdf
I am utilizing my existing Robert Shaw 9420 thermostat in conjunction with TrueIAQ to operate the TrueSteam humidifier. The TrueIaq diagram on page 12 shows that the C wire, originating from HVAC, is hijacked from the thermostat and to be wired into the C pin on TrueSteam Internal. The RS 9420 thermostat requires use of the C wire for operation as per page six of its manual. Do I wire the C wire from HVAC to both RS 9420 thermostat and Truesteam like the routing of the R wire depicted on the True IAQ diagram?
mjbxx is offline   Reply With Quote
Old 01-21-2009, 10:35 PM   #2
yes must be hooked to both. tstat needs it as well as the hstat (although i dont know why) are there lights on the hstat? if so more than likely thats the only reason to hook up the common nevermind just looked at the hstat all i can say is holy crap thats complicated lots ofoverkll there considering all you really need is one line in and one out to turn it on and off. add just a couple more sets of contacts and you could have it open the garage door and start your car.. have fun
kennzz05 is offline   Reply With Quote
Honeywell TrueSTEAM with TrueIAQ Digital Control mjbxx HVAC 11 02-01-2009 01:25 PM
