Thermostat (Totaline) Won't Maintin Temp - HVAC - DIY Chatroom Home Improvement Forum
Old 02-02-2011, 12:10 PM   #1
Post
Thermostat (Totaline) won't maintin temp
I have a Totaline wireless thermostat model number P474-1100. The thermostat is set to 65 degrees. When I woke up this morning the temperature was 50 degrees in the house but the thermostat was still set to 65 degrees. When I adjust the temperature by either pressing the up or down arrows the heat will turn on. The furnace does continue to run a few cycles but will not maintain the desired temperature. Why do I have to continue to adjust the temperature on the thermostat for the heat to come on? Is something wrong with the thermostat and wireless control box located by my furnace?
bribin is offline   Reply With Quote
Old 02-02-2011, 01:27 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
when adjusting the stat down and then up you are basically resetting the system. The problem is in your equipment not the stat most likely. What kind of equipment do you have? heat pump (all electric) or HP w/gas or just gas ?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 02-02-2011, 01:30 PM   #3
My equipment is just gas.
Old 02-02-2011, 01:36 PM   #4
AKA HVACTECHFW
model #? Brand? while the system is acting up. if 90% efficient (pvc vent pipes) then ensure the intake and exhaust are clear.
IT IS WHAT IT IS
Old 02-02-2011, 03:15 PM   #5
It is a Tempstar. The number I found on it is 1002614A. When I looked at Tempstar's website it kind of looked like the PS90 furnace. How do I find the model number?
Old 02-02-2011, 03:16 PM   #6
I forgot to mention it also said 5000 on the furnace.
Old 02-02-2011, 03:25 PM   #7
AKA HVACTECHFW
good enough we know its a tempstar. should be a window in the blower door and you'll see some flashing lights or light. while it is acting up!!! check this and tell us how many flashes. also after you have counted the flashes, remove the blower door and check the back of it for a legend that states what the code means. this may also be on the other door of the furnace.
IT IS WHAT IT IS
Totaline thermostat ejhibbard HVAC 5 12-26-2010 05:28 PM
Replacing Old Thermostat with Totaline 40bill40 HVAC 1 05-14-2010 05:26 PM
Totaline thermostat trouble shooting Goldwing93 HVAC 3 07-30-2009 11:35 PM
with all bedroom doors shut does thermostat read correct temp? windowguy HVAC 19 04-20-2009 09:17 AM
Totaline thermostat to work with two wires evlap HVAC 8 11-15-2008 08:49 PM
