Thermostat Switched To Celcius...Help - HVAC - DIY Chatroom Home Improvement Forum
Old 02-13-2011, 07:50 PM   #1
Thermostat switched to Celcius...Help
First off it is a basic basic honeywell digital non-programmable thermostat. It has the two switches at the bottom to select auto/on and cool/off/heat and the screen is a single display with only two arrow shaped buttons to change temp setting. Deminsions are approximately 3" X 3". Very baxic.
Here is my question, how do I change it from Celius back to farenheit? It seems my mother-in-law() saw fit to mess with it and now it reads Celcius.
Thanks for any help.
bcdad is offline   Reply With Quote
Old 02-13-2011, 08:17 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,756
Look inside it by the batteries or on the back for a model # and google it ie: RTH 2100 owners manual and you may find one on the net. Usually you have to switch it to OFF and press and hold both those buttons at the same time. Then a menu comes up and you use the up/down arrows to scroll thru it and find an item to change. I WOULD NOT attempt that w/o the manual as you could change another setting and make it worse.
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
Thermostat issues rathipon HVAC 4 01-29-2011 11:46 AM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 05:40 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
How to set Hunter Thermostat to Celcius Red Squirrel HVAC 2 09-17-2009 09:59 AM
