Thermostat Settings? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-10-2011, 10:53 AM   #1
I am going in for some surgery on Monday, and will be resting at my parents house. I will be away from my place for a while, and just seeing what I should put my thermostat temps at? I have a programmable thermostat that has four different time settings. Currently they are set at
5:45 am-7 am 72 deg
7-4:45pm 60 deg
4:45-10pm 72 deg
10pm-5:45am 60
The temps in NW MO have been getting down into the 30's at night and 50-60's in the day. I will have someone checking on the place while I am gone, just need to see what I should go ahead and set this at since there will be nobody there during the time I'm gone.
ws450r is offline   Reply With Quote
Old 11-10-2011, 12:07 PM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Don't have an answer for you, but you might consider turning your hot water heater down too.
Old 11-10-2011, 01:20 PM   #3
Rewards Points: 6,652
Set for 60 and leave it. Water heater, set for warm, or lowest position, Have someone check on the place if they can, to pick up mail, switch different lights on, and check to make sure no water leaks, etc.
Old 11-10-2011, 04:34 PM   #4
An old Tradesmen
Rewards Points: 6,464
55 to 60 for temp, and as said, water heater to warm or vacation.
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 05:32 PM
2 stage heating and thermostat settings BlueBSH HVAC 4 12-17-2009 09:07 AM
LSI thermostat stage settings trouble! weydoggy HVAC 1 11-27-2008 10:26 AM
How to optimize thermostat settings (2 heating systems same home) rossl56 HVAC 1 11-26-2008 04:39 AM
