-   -   Thermostat setting questions: efficiency question (http://www.diychatroom.com/f17/thermostat-setting-questions-efficiency-question-163280/)
Grayguy 11-13-2012 11:13 PM
I'm not sure if this should be here or in general, so mods I apologize.
I recently installed a digital programmable thermostat in my house and It has led me to a few questions. The factory settings for the heat adjustment had it going from 64F all night to 72f in the A.M. That seems like a large gap to me. From an efficiency stand point, aren't you just going to burn all (or more) of the oil you saved by lowering the temp all night trying to heat the cold house back up in the AM? What is the most temperature variance you can use while still being as efficient as possible?
HVACTECH96 11-14-2012 07:05 AM
I suggest no more than 5 deg setback based upon homeowner feedback.I know there is a percentage of savings for every degree, but I cant remember that figure right now.I've had homeowners tell me they have tried both setting back and keeping at one temp, and not showing any difference in gas usage.
bob22 11-14-2012 08:00 AM
Government says:"You can save as much as 10% a year on heating and cooling by simply turning your thermostat back 7-10F for 8 hours a day from its normal setting."
However, they've some comments on HEAT PUMPS, ELECTRIC RESISTANCE HEATING, STEAM HEAT, AND RADIANT FLOOR HEATING systems:
http://energy.gov/energysaver/articl...ontrol-systems
gregzoll 11-14-2012 08:42 AM
I decided this year that instead of going from 69 to 62, to set to 65 at night and away. Summer, we keep it around 72, since the system runs more efficient with a/c, since you are not placing a large heat gain on it.
Only time that I would set to say 60 in the Winter, or 78 in the Summer or maybe 82, would be when you are away on vacation. People have this false sense of security, that the more they setback the thermostat, the more they will save. In turn they are wasting money, because they do not fully understand how the house/apt/structure works along the hvac system.
TheBobmanNH 11-14-2012 09:57 AM
I'd say trial and error on this one, but... for my money, the lower the better (within reason). If your house is going to drop 10 degrees overnight, your heating system would have had to have been running to try and maintain that temperature all night, rather than just running once in the morning. Seems like a no-brainer to me.
jagans 11-14-2012 07:18 PM
set it back
The fact is that the hotter you make it inside the more pressure there is trying to equalize the indoor and outdoor temperature. In other words its not a straight line differential. I have found over the years that setting the night temperature to back to 65 degrees at 11:00PM, and 68 degrees at 5:00AM (About a half hour before we get up) has several advantages:
1: Less sickness. Hot air dries out your nasal passages, and you get up like you have a damn hangover.
2: Efficiency: You burn less fuel.
If somebody wants it hotter than 68 degrees, tell them to put on a sweatshirt, or run around the block to get some exercise.
