Thermostat Screen Is Blank - HVAC - DIY Chatroom Home Improvement Forum
Old 11-05-2012, 04:00 PM   #1
sweaty
Rewards Points: 276
Thermostat Screen is Blank
My Carrier thermostat screen is blank and the heat pump is not running. All circuit breakers are on. Just this morning, the thermostat was on. It's getting cold.
I guess it's possible that the kids hit it with a pillow or something, but it is still attached to the wall. How do I take it off? Can I diagnose this without calling an EXPENSIVE repairman?
sweaty is offline   Reply With Quote
Old 11-05-2012, 04:36 PM   #2
sweaty
Rewards Points: 276
Never mind, I fixed it. It seems the cover was just not on tight.
Old 11-05-2012, 05:06 PM   #3
Rewards Points: 582
good to hear ...but don't hold your breath....its never that easyben sr
Old 01-02-2013, 03:23 PM   #4
sweaty
Rewards Points: 276
It went blank again, for the third time. The previous times, I could open and close the door (not to the buttons, but to all the electronic parts) a few times and it went on. Not today. Is it just a loose connection?
Help! It's getting cold!
Old 01-02-2013, 03:32 PM   #5
sweaty
Rewards Points: 276
I "fixed" it. I opened and closed the door partially, the screen got a signal, I closed it all the way, and I have heat.
I am concerned that, next time, it won't be so easy.
Old 01-02-2013, 06:50 PM   #6
Rewards Points: 616
you got the hang of it now..... maybe time for a new stat someday...
carmon is offline   Reply With Quote
Old 01-02-2013, 07:03 PM   #7
Rewards Points: 196
Sometimes bending the pins ever so slightly , to get a better connection between stat and subbase works, but beware the pins are delicate.Your probably better off replacing tstat.
HVACTECH96 is offline   Reply With Quote
Old 01-02-2013, 07:50 PM   #8
AKA HVACTECHFW
Rewards Points: 1,208
You have an air flow issue!!!! The screen goes blank when the main limit opens and shuts power off through the R circuit. When you open and close the door your effectively reset the system. This is an educated guess, but maybe next time the screen goes blank you should check for a diagnostic flash code before you open and close the door.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
carmon (01-02-2013)
Old 01-02-2013, 10:21 PM   #9
Missouri Bound's Avatar
OK...what door are we opening and closing? The thermostat? The furnace?
Do you want it your way or the right way?
Old 01-02-2013, 11:02 PM   #10
AKA HVACTECHFW
either one, it doesn't really matter.
IT IS WHAT IT IS
Old 01-03-2013, 01:10 PM   #11
Rewards Points: 590
Hopefully not the front door... after all, it's cold out there!
operagost is offline   Reply With Quote
Thermostat Blank Screen jpeyster58 HVAC 1 09-22-2012 11:37 AM
Honeywell screen went blank Master Brian HVAC 19 06-28-2012 10:34 AM
Carrier 8000T Thermostat blank jeffetdiy HVAC 4 02-03-2011 09:11 PM
Thermostat blank - no heat/ac - fan works snosurfa7 HVAC 4 10-29-2010 11:42 AM
Help for a locked screen on a Honeywell TH8320 thermostat TanyaMendenhall HVAC 3 06-15-2009 10:05 PM
