Thermostat Schematic - HVAC - DIY Chatroom Home Improvement Forum
Old 12-15-2008, 09:55 PM   #1
Speedbird's Avatar
Can anyone direct me to the schematic for wiring in a single stage HEAT/COOL thermostat? I have a separate gas furnace and an outside AC driven by a Hunter 49999B thermostat. I am trying to visualize/understand how the thermostat is able to control both units with the FAN/COOL/HEAT switches.
Speedbird is offline   Reply With Quote
Old 12-16-2008, 09:35 AM   #2
See if this helps as a primer. Be sure to check out the diagram.
dac122 is offline   Reply With Quote
Old 12-16-2008, 10:26 PM   #3
Speedbird's Avatar
Thank you that is exactly what I was looking for. Now I understand how my systems are controlled thru the T stat
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 04:29 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 04:57 PM
