Thermostat Reset From Lockout - HVAC - DIY Chatroom Home Improvement Forum
Old 03-04-2010, 02:43 AM   #1
Lightbulb
Thermostat reset from lockout
Okay guys I am a student with minor field experience so bear with me.
I walked up to the thermostat and it was on hold at 77 degrees farenheit in heat mode. Cooling mode is fine. The t stat was a honeywell by the way but that is irrelevent. Basically I heard that there is a certain way to figure out how to get the t stat out of lockout depending on the buttons on the t stat where there is run program, and hold on the right side and on the left side the tstat buttons are schedule and time. I was never taught how to figure out the combinations of buttons to press to bring it out of lockout and I know that if I disconnect power from the t stat the memory will keep it on hold anyway so that would be pointless. So if you guys can just let me know how to do this that would be cool because what kind of tech would I be if I didnt know it right.
Aaron87642 is offline   Reply With Quote
Old 03-04-2010, 03:50 AM   #2
An old Tradesmen
Rewards Points: 6,086
If your asking how to get it to follow the program again. Basically, just push "run program". Thats not a lockout, its just a hold temp feature.
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
Two Wire 24V Thermostat to Digital Thermostat on Pellet Stove jrodtaclet Electrical 4 09-15-2009 06:37 PM
Replacing thermostat...................... sktn77a HVAC 6 09-02-2009 11:07 PM
ac/furnace runs whatever thermostat settign donbohn HVAC 1 06-20-2009 06:42 AM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 04:57 PM
