Thermostat Replacement - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-02-2012, 10:09 PM   #16
GC/Master Plumber/Mech
Rewards Points: 560
Originally Posted by trishden View Post
I do have 24v from R to G. If i set the stat to cool the a/c unit comes on and the furnace blower comes on????????????
That apparent. Now you should set up the stat. Being that it is a heat pump the stat needs to know this so that the function of O can be used for the reversing valve. Different programming for a Heat pump, gas furnace and so on. If you haven't configured the stat please do so.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 03-02-2012, 10:12 PM   #17
Guys is there anywhere i can go on the web to a conversion diagram from my old stat to the new one. its getting pretty chili in here and we are expecting snow in the am
trishden is offline   Reply With Quote
Old 03-02-2012, 10:13 PM   #18
Rewards Points: 560
Did you open the link that I provided you.
Chart there and even an 800 number to Honeywell for tech advise
Old 03-02-2012, 10:36 PM   #19
Guys the heat pump set up was the ticket. did the programing and everything kicked on . can't thank you guys enough
Old 03-02-2012, 10:40 PM   #20
Missouri Bound's Avatar
Glad to hear it...now keep warm....
Do you want it your way or the right way?
Trane Thermostat replacement Maursce HVAC 14 11-09-2012 09:39 PM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
Thermostat replacement goalie35 HVAC 2 11-13-2010 02:10 PM
Ritetemp 6036 replacement thermostat deanrfire HVAC 0 01-15-2010 01:12 AM
24v thermostat replacement rolat99 Electrical 1 10-24-2009 07:36 PM
