Thermostat Replacement - HVAC - DIY Chatroom Home Improvement Forum
Old 03-02-2012, 07:09 PM   #1
Thermostat replacement
I am replacing a trane weathertron (model # BAYSTAT239A) with a honeywell RTH6350. wired it as follows:
OLD - NEW
L = not used
X2 = Black = E
W = White = AUX
G = Green = G
O = Orange = O/B
Y = Yellow = Y
R = Red = RC (which is jumpered with R on the new stat)
B = Blue = Not used
T = Tan = not used
My furnacre will not come on can any one help me please.
Last edited by trishden; 03-02-2012 at 07:25 PM. Reason: forgot some information that might be helpful
trishden is offline   Reply With Quote
Old 03-02-2012, 08:02 PM   #2
Houston204's Avatar
Rewards Points: 556
The old B is C if the new stat has that terminal.
If you forgot to turn off power to the indoor unit, you may have popped a low voltage fuse.
Houston204 is offline   Reply With Quote
Old 03-02-2012, 08:19 PM   #3
The new stat does not hace a c terminal it has a L terminal that is not being used. I did turn of the inside power at the furnace breakers , not at the electrical panel
Old 03-02-2012, 09:01 PM   #4
Missouri Bound's Avatar
Do you have a multimeter....check for voltage at the stat.
Do you want it your way or the right way?
Old 03-02-2012, 09:39 PM   #5
The thermostat does not have any power. if i take the batteries out i have no display on my stat. I have checked the low voltage fuse and it is not blown. If i take the fan off of the auto setting and put it on the ON setting the fan will come on. the furnace has a heat pump
Old 03-02-2012, 09:43 PM   #6
It should have a display without batteries. Do you have a multimeter?
Old 03-02-2012, 09:45 PM   #7
yes sir i do
Old 03-02-2012, 09:48 PM   #8
Have you tested the voltage to the thermostat? The fan switch is mechanical...it won't need the thermostat to work properlly for the switch to work. If you have voltage to the thermostat and it does not work, you have either wired it incorrectly or the stat itself is bad.
Old 03-02-2012, 09:52 PM   #9
wHAT VOLTAGE AM I LOOKING FOR
Old 03-02-2012, 09:55 PM   #10
GC/Master Plumber/Mech
Rewards Points: 560
You stated that you can turn the fan on with the stat so the voltage is there.
Did you go through the set up procedure for the stat?
Programming the stat for a heat pump?
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 03-02-2012, 09:58 PM   #11
Rewards Points: 560
Unless I'm wrong it still take 24 vac from terminal R to G to make the fan work.
Old 03-02-2012, 10:00 PM   #12
No sir and i can not find that in the owners manual
Old 03-02-2012, 10:02 PM   #13
That is correct...but it's a mechanical switch, it doesn't require anything from the thermostat other than a switch. A thermostat wired improperly (except for that switch) will control the fan.
Old 03-02-2012, 10:02 PM   #14
Rewards Points: 560
Here's a link to the manual
http://customer.honeywell.com/techli.../69-2416ES.pdf
Page 13 for set up.
This may fix your problem by setting up the stat for your system
Old 03-02-2012, 10:05 PM   #15
I do have 24v from R to G. If i set the stat to cool the a/c unit comes on and the furnace blower comes on????????????
Trane Thermostat replacement Maursce HVAC 14 11-09-2012 09:39 PM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
Thermostat replacement goalie35 HVAC 2 11-13-2010 02:10 PM
Ritetemp 6036 replacement thermostat deanrfire HVAC 0 01-15-2010 01:12 AM
24v thermostat replacement rolat99 Electrical 1 10-24-2009 07:36 PM
