Thermostat Question - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-03-2011, 08:21 PM   #16
One more question and I will leave you guys alone.
Will either of these stage the aux heat as described below:
Call for stage one (heat pump) if needed call for stage two (first stage if resistance heat) also if needed call for stage three (second stage if resistance heat).
http://www.prothermostats.com/produc...product=110907
http://www.prothermostats.com/produc...product=100926
andythedrew is offline   Reply With Quote
Old 09-03-2011, 08:24 PM   #17
AKA HVACTECHFW
Rewards Points: 1,208
YES, either one will work.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 09-03-2011, 09:05 PM   #18
An old Tradesmen
Rewards Points: 8,164
No, they won't. they can't control 2 stages of aux heat. The first one you linked to earlier can though.
Old 09-03-2011, 09:50 PM   #19
Here is the diagram. I drew it up real quick. The diagram assumes that w1,2 and 3 are not energized in em heat. I do recommend em heat. My heat only fails when im working out of town, and my wife is an angry technician..
Master of Cold is offline   Reply With Quote
Old 09-03-2011, 09:55 PM   #20
Before anyone starts screaming..yes I see the error of my ways....I was reworking the em heat and was distracted by a shiny object...
Old 09-03-2011, 10:08 PM   #21
Thanks guys I think i have a pretty good idea on what i need to do. I appreciate all the input.
Old 09-03-2011, 10:49 PM   #22
Okay..let's try this again..
Remember..a guy that was drinking jack daniels made this..electrocution is your responsibility.
But in all seriousness. If yu do use this pay close attention to your connections and how many amps will be pulled through that connection. Each strip will draw approx 17-20 amps. If you put 2 together that's 34-40, which would require 6ga wire. Don't burn the house down to save a few bucks.
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
question on old thermostat wiring for upgrade jthn HVAC 2 01-02-2011 11:07 PM
Question on installing an Honeywell RTH6350 programmable thermostat. outdoorted HVAC 3 01-02-2011 06:48 PM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 05:40 PM
Thermostat question ctown HVAC 7 12-05-2006 03:46 PM
