Thermostat Question - HVAC - DIY Chatroom Home Improvement Forum
Old 09-03-2011, 03:54 AM   #1
Question
Thermostat Question
http://www.prothermostats.com/produc...product=172406
Hey guys,
First of all thanks for the forum and for any answers you may be able to give.
Can some one tell me with reasonable certainty if the thermostat that I linked to above will control two stages of AUX resistance heat independently?
In other word will it behave as follows?
Call for stage one (heat pump) if needed call for stage two (first stage if resistance heat) also if needed call for stage three (second stage if resistance heat).
If it will or will not are there any others that will? (preferably a cheaper model.)
Again thanks for any help.
andythedrew is offline   Reply With Quote
Old 09-03-2011, 05:42 AM   #2
An old Tradesmen
Rewards Points: 6,148
Yes, it can control the heat as you want.
The Following User Says Thank You to beenthere For This Useful Post:
andythedrew (09-03-2011)
Old 09-03-2011, 09:39 AM   #3
Usually the second stage of electric strips (your 3rd stage) is controlled in the unit by a time delay sequencer. Or they are wired to bring on all the strips at once.
What kind of air handler do you have? And what is the kw total of the strips?
Master of Cold is offline   Reply With Quote
Old 09-03-2011, 01:55 PM   #4
It is a goodman aruf unit. It has a 10kw and a 5kw. Right now they are wired to come on all at once. I want to wire the second stage to the 5 kw and the third to the 10kw hoping it will keep the 10 from coming on unless absolutely necessary.
Old 09-03-2011, 03:01 PM   #5
Im assuming your new stat has w-1,2 and 3.
The issue is in the defrost cycle. The condenser is going to send a signal back to the air handler during the defrost period, to turn on the heat strips. The unit is in the cooling mode during this time. Usually (but not always) its the white wire that goes to the air handler from the condenser that gets energized. This will enable the strips to come on. How many strips you need to come on is going to be determined by the outdoor temp, the size of the unit, and the indoor temp. I keep the house at 75 in the winter. My average defrost time is about 45 seconds, at 32 outdoor temp.
If your system takes longer to defrost, and you don't have enough strip heat going, you will be cooling your house. Each strip is roughly 18k btu.
So if you need 10kw to come on during defrost, you will only be able to use the w1 and 2 terminals on the thermostat.
Old 09-03-2011, 05:32 PM   #6
I have considered this. I was thinking I would use a relay to energize both strips on a defrost.
Before I got too deep into figuring out how to do this I wanted to make sure I could get a stat that would do what I wanted.
Does my defrost approach sound reasonable?
Old 09-03-2011, 06:02 PM   #7
An old Tradesmen
Post the full model number of the outdoor unit. You may only need 10KW of strip on during defrost.
Old 09-03-2011, 06:08 PM   #8
AKA HVACTECHFW
Rewards Points: 1,208
yes, you could use a relay to control both stages on a defrost call and also control them independently from the stat.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 09-03-2011, 06:28 PM   #9
My outdoor unit is a goodman ssz140421ad.
Old 09-03-2011, 06:33 PM   #10
An old Tradesmen
By only bringing on 10KW of strip, at worse during defrost, the air temp out of the registers will be 6 degrees cooler then room air temp. But some people are uncomfortable if that cooler air blows on them. So you need to decide if your comfort is more important for those few minutes. or the operating cost.
Old 09-03-2011, 06:45 PM   #11
Thanks for the info I had been considering just using the 10kw for defrost.
While we are on the topic of defrost what do you think would be a proper defrost timer setting for central Alabama? I am pretty sure it is set for 30 min which is way to short in my opinion but I want to make sure that it does not need to be that short for this region. Thanks again.
Old 09-03-2011, 07:55 PM   #12
I would go 60-90.
Maybe beenthere can tell us if this unit has demand defrost control, or just a run timer
Old 09-03-2011, 07:57 PM   #13
Dead center halfway between Birmingham and Huntsville.
Old 09-03-2011, 07:58 PM   #14
I am pretty sure it is just timer.
Old 09-03-2011, 08:56 PM   #15
An old Tradesmen
Set it to 90. Goodman heat pumps are timer. They don't have any models that use on demand defrost.
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
question on old thermostat wiring for upgrade jthn HVAC 2 01-03-2011 12:07 AM
Question on installing an Honeywell RTH6350 programmable thermostat. outdoorted HVAC 3 01-02-2011 07:48 PM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 06:40 PM
Thermostat question ctown HVAC 7 12-05-2006 04:46 PM
