Thermostat Problems - HVAC - DIY Chatroom Home Improvement Forum
Old 01-24-2009, 07:00 PM   #1
Thermostat problems
I have a Hunter 44110 digital thermostat. When I set the fan to auto, the system to heat, and the desired temperature higher than ambient, I can hear the relay click but the fan does not turn on. If I then set the fan to on, it starts blowing warm air. Once it reaches the set temperature, the heat shuts off and the fan recirculates the air.
When the system is set to cool and the fan to auto, everything functions as it should. The problem started when I replaced the old mechanical thermostat with aforementioned digital one. Any ideas how to fix this issue?
thanks in advance
thegiven46 is offline   Reply With Quote
Old 01-24-2009, 07:13 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,454
Sounds like a furnace control board fan relay issue to me. Post the make, model and serial # of the furnace and we may be able to help.
Old 01-24-2009, 07:54 PM   #3
biggles's Avatar
is this a recent problem with "no fan at all" in the auto fan/heating mode. there is a time delay either thru the relay board or a temperature disc that closes the fan circuit down in the furnace for the fan to run "in auto"
Old 01-24-2009, 10:30 PM   #4
An old Tradesmen
Rewards Points: 6,576
Is it an electric furnace.
Some thermostats need to be set to turn on the fan during a heat call, on older electric furnaces.
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 04:29 AM
Thermostat problems. virghmd HVAC 5 01-18-2009 02:53 AM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 04:57 PM
mini fridge thermostat problems furniture_guy Appliances 1 12-19-2006 07:55 AM
