Old 10-12-2011, 12:09 AM   #1
thermostat problems
following the advice of another member, i am posting this here as well as in electrical.
recently i upgraded (or rather tried to upgrade) to a new thermostat, i followed the directions and replaced wire for wire. simple i thought, WRONG...i can't get the heat or A/C to operate and the only thing that does work is the blower fan. existing wires are Red, Blue, Brown, Green, White, and Yellow. i have tried various combinations and have fallen way short of achieving success. i humbly ask for help.
the thermostat i am trying to use is a Hunter model #44660, A/C is a Carrier (unsure of age), furnace is also a Carrier (electric pilot light).
any and all help is greatly appreciated.
irish_father is offline   Reply With Quote
Old 10-12-2011, 12:21 AM   #2
JJboy's Avatar
thermostat problems
First you have to check that the wires colors are connected at the right place on the control board. After that you just need to following the thermostat manual.
Red ( 24vac ) - R
White ( call for heat ) - W or W1
Green ( Fan On ) - G
Yellow ( call for cool ) - Y
Orange - O/B
These are the basics
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-12-2011, 06:19 PM   #3
REP
thermostat problems
What was the old stat and what did the existing wires connect to on that?
REP is offline   Reply With Quote
Old 10-12-2011, 08:24 PM   #4
thermostat problems
We don't use the brown much in the field. Like JJ was saying, look at the control board and see what color wires are attached to the terminals. The terminals on the control board will be the same designations as what is on the thermostat.
Master of Cold is offline   Reply With Quote
Old 10-12-2011, 10:35 PM   #5
thermostat problems
Maybe?:
http://highperformancehvac.com/hvac-...at-color-chart
diyorpay is offline   Reply With Quote
Old 10-13-2011, 12:16 AM   #6
thermostat problems
Originally Posted by diyorpay
What if the original installer didn't follow the chart?
Old 10-13-2011, 10:20 AM   #7
thermostat problems
first problem is your putting a hunter thermostat on a carrier. That shoud be against the law.
Your brown should be your common or c terminal but it could also be the reversing valve since you dont have an orange wire. If it is indeed common it will eliminate the need for batteries.
Rewire it as you removed the wires as not to get confused when you discover whats actually the problem.
Why change t-stat? Was it working prior to the change? Make sure you have a heat pump t-stat and not conventional.
Patrick Eubanks is online now   Reply With Quote
Old 10-13-2011, 05:39 PM   #8
Professional
thermostat problems
Where did the OP say they had a heat pump?
IT IS WHAT IT IS
hvactech126 is online now   Reply With Quote
Old 10-13-2011, 08:41 PM   #9
thermostat problems
Heat pump was assumed due to the fact of having 6 wires at the stat. What we are probably looking at is 2 stage heat.
Old 10-13-2011, 08:48 PM   #10
Professional
thermostat problems
nevermind
IT IS WHAT IT IS
Old 10-14-2011, 09:45 AM   #11
thermostat problems
after reading the initial post I this it is conventional but I stick with my origingal statement about the t-stat. Stick with the old stat
Heat but no A/C with new thermostat myqhenry HVAC 15 05-30-2011 11:53 PM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 06:40 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
FAULTY THERMOSTAT!!! What the He.... Krazecon HVAC 11 02-12-2009 05:26 AM
mini fridge thermostat problems furniture_guy Appliances 1 12-19-2006 07:55 AM
