Thermostat Problem (hopefully!) - HVAC - DIY Chatroom Home Improvement Forum
Old 09-09-2012, 04:17 PM   #1
Question
thermostat problem (hopefully!)
Hi Guys,
I'm having a issue hopefully I can get some insight on. My a/c or heater will not kick on. The fan is set to "auto" and is running non-stop. There is a switch, like a light switch, that can be used to turn the system on and off, and when I flip the switch, the unit will kick on, but turns off after about 10-15 seconds. I've replaced the batteries and I've tried jumping the 'Y' and 'G' wires, but got nothing. The a/c unit is new this year. Any help you can offer is appreciated. Thanks in advance!
curtdiggy513 is offline   Reply With Quote
Old 09-09-2012, 05:27 PM   #2
HOTDAWG
You need to jump the R and W to remove the tstat out of the equation. If your furnace fire up and stays on then you know its the stat.
Affordable Comfort, assisting with furnaces Barrie and surrounding area, as well as offering 24 hour furnace repair
Acomfort is offline   Reply With Quote
The Following User Says Thank You to Acomfort For This Useful Post:
curtdiggy513 (09-09-2012)
Old 09-09-2012, 05:48 PM   #3
Thanks for your response. i tried this and had no luck. It did the same thing. Kicked on for about 15 seconds and then off. Is it a good sign that it will even kick on at all?
Old 09-09-2012, 05:53 PM   #4
HOTDAWG
Are your burners coming on at all ?
Old 09-09-2012, 05:54 PM   #5
Hi are you saying the furnace fires up and then shuts down after the 15 secs or the a/c ?
hvac dude is offline   Reply With Quote
Old 09-09-2012, 07:13 PM   #6
Okay, I went and stood by the a/c unit and it is not turning on after all. When I turn the switch on, the fan gets louder for the 15 seconds, but the unit outside does nothing. It is the same for the heater. Neither will kick on. I can hear an audible click from the therm, which is usually followed by something turning on, but now, nothing.
Old 09-09-2012, 07:24 PM   #7
I would go to yur thermostat disconnect the r w y g wires make sure they dont touch each other (turn power to furnace off) . turn power back on once wires are disconnected and connect the r an g wires together the fan on the furnace shud start and run on , let me know what happens at this stage ,what switch and what fan goes louder
Old 09-09-2012, 07:28 PM   #8
i also just noticed you jumpered y and g b4 is that correct ? if so you may have blown the control fuse on the transformer or tripped the mini circut breaker on transformer if equipped with one ,
Old 09-09-2012, 09:30 PM   #9
I tried this as well and got the same results. Where is the transformer located? At this point, is this something that's out of my hands? I honestly can't afford to call a repair man.
Old 09-09-2012, 09:30 PM   #10
Rewards Points: 1,192
Was the unit new? Sounds like a warrenty issue.
bobelectric is offline   Reply With Quote
Old 09-09-2012, 09:35 PM   #11
HOTDAWG
Honestly, at this point I would say its time to call someone in... If you want to look at the back of the board for any scorch marks, it's sounding like a board issue to me.
Old 09-09-2012, 09:36 PM   #12
transformers located in the furnace around the circut board area , upload some pics if u can .of area by electrical on furnace . hope u tuned power back on b4 connecting r to g ?
Old 09-09-2012, 11:10 PM   #13
Send some pictures if you take the panel off the heater and call for heat you should have a red light that blinks look at the backside of the panel for the code and it will give you a list of issues.
afrye707 is offline   Reply With Quote
Old 09-10-2012, 06:34 AM   #14
biggles's Avatar
Y to G isn't a jump R to Y is condenser out side and R to G is the supply fan on the furnace....once you pull the stat off the subbase a jump is the only thing that will give you an action...try G to R for supply fan........if your getting any actions on any jump you have 24Vsfrom the TR
Programmable Thermostat Problem HandyHunter HVAC 19 04-01-2012 07:56 PM
Thermostat or oil burner problem? freyguys HVAC 5 02-25-2010 01:44 PM
Changed thermostat and have problem ssmcalister HVAC 3 10-29-2008 04:40 PM
Hunter Thermostat Problem kohlernm HVAC 1 11-22-2007 09:58 PM
Thermostat Wiring Problem crazy woman HVAC 2 08-15-2006 09:22 AM
