Thermostat Problem? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-06-2009, 12:58 PM   #1
Thermostat problem?
Hi , Im trying to figure out if the problem im having lies in the t-stat, I have a heat pump & the furnace wont kick in the second stage (propane) unless i manually adjust the t-stat to a higher setting. Ive checked the differential adjusments & the second stage should be kicking in after 15 minutes of heat pump activity. its almost like the timer in the t-stat went out. any thoughts or suggestions would be greatly appreciated. btw im running a trane xb-90 furnace, american standard heat pump kit tayplus103a & robertshaw 9240 t-stat. Thanks.
journeymanj is offline   Reply With Quote
Old 12-06-2009, 02:46 PM   #2
An old Tradesmen
Rewards Points: 7,256
Why do you only want the heat pump to run 15 minutes.
Thats not much of a run time for a heat pump.
Old 12-06-2009, 03:25 PM   #3
Thats just where i set it after making sure it wasnt a programming issue, ill make it longer when i get it figured out, the last 2 (cold) nights ive been getting an error message & the heat pump has been running for hours until I move up the set-point on the t-stat, then the propane back-up kicks in & everything is fine until the next cycle.
Old 12-06-2009, 05:36 PM   #4
An old Tradesmen
Dual fuel kit is set up or wired wrong.
Is the temp dropping in your house. if not, then it shouldn't switch over to the gas furnace.
Old 12-06-2009, 09:27 PM   #5
yes, the er code on the robertshaw t-stat means the unit isnt keeping up with demand,you would think if the problem is in the dual fuel unit it wouldnt go to propane just by bumping the t-stat up a couple degrees, that is why im leaning towards a bad t-stat.
Old 12-07-2009, 03:25 AM   #6
An old Tradesmen
Its the dual fuel kit that is suppose to stop it from going to LP unless its needed. Even when bumped up a couple degrees.
I'd recheck the wiring before just getting a new stat.
Old 12-07-2009, 05:16 PM   #7
Thanks, ill have to read up on it & see what`s up with it, I just moved in here & have always had natural gas systems & not exactly sure how these are supposed to operate.
Thermostat problem vtec69 Electrical 7 11-27-2009 10:07 AM
Two Wire 24V Thermostat to Digital Thermostat on Pellet Stove jrodtaclet Electrical 4 09-15-2009 05:37 PM
Replacing thermostat...................... sktn77a HVAC 6 09-02-2009 10:07 PM
Thermostat wiring jetmanaz HVAC 1 08-09-2009 07:13 PM
2 stage heat thermostat problem W1 AND w2 wires whatdoIdonow HVAC 6 11-26-2006 12:04 AM
