Thermostat Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 02-13-2008, 08:11 PM   #1
Wink
thermostat problem
My gas heater thermostat does not start the fan in automatic mode. I have to swith th 'ON" to start the fan It has been working fine until recently. Can any one help?
prthomas4@hotmail.com is offline   Reply With Quote
Old 02-14-2008, 07:21 AM   #2
30 year tech
hvac122's Avatar
Sounds like a problem with the furnace, not the thermostat.
hvac122 is offline   Reply With Quote
Old 02-14-2008, 08:28 PM   #3
Smile
Thanks I will check it out
Old 02-14-2008, 08:40 PM   #4
biggles's Avatar
it is either your fixed fan disc or adjustable round dial honeywell(fan comes on after the heat exchanger heats up) or thru the solid stat board on a timed delay after the burner comes on,
Old 02-15-2008, 09:30 PM   #5
hms
Remodeling contractor
could be fan switch, overload safety device, t-stat, etc. process of elimination.
hms is offline   Reply With Quote
Ford Ranger Thermostat Problem? suzikg Automotive Repairs 21 04-18-2014 10:54 AM
Hunter Thermostat Problem kohlernm HVAC 1 11-22-2007 09:58 PM
2 stage heat thermostat problem W1 AND w2 wires whatdoIdonow HVAC 6 11-26-2006 12:04 AM
A/C Thermostat Problem therumblefish HVAC 7 11-01-2006 08:08 PM
Thermostat Wiring Problem crazy woman HVAC 2 08-15-2006 09:22 AM
