Thermostat Problem? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-26-2012, 01:17 PM   #1
Thermostat problem?
Hey guys, New here. My Thermostat has been giving me trouble since yesterday, it will randomly go blank, no letters or lights or anything. I've found if i go outside to the Unit and switch the outside breakers off then on. That turns the thermostat back on and everything will work smooth, for about 3 hours, then it will do it again. And the T stat i'snt battery operated, it run off power from the wires behind the T stat. When the unit kicks on it heats the house find and works good, no strange noises coming from it or anything. Any thoughts??
brianbenedict is offline   Reply With Quote
Old 11-26-2012, 02:24 PM   #2
Rewards Points: 50
What brand and model?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 11-26-2012, 03:22 PM   #3
The unit is Luxaire, The T stat is honeywell TH5220D1003
Old 11-26-2012, 04:21 PM   #4
Rewards Points: 50
No expert but I would replace stat and see what happens. If it contionues, then I would say you have a wiring issue and or power issue to stat.
Hopefully some experts will chime in soon!
Thanks,
Ed
Old 11-26-2012, 04:26 PM   #5
Thank you for your help! i shall try and replace the stat. Ill post the outcome.
Old 11-26-2012, 04:46 PM   #6
An old Tradesmen
Rewards Points: 6,516
Is there a condensate pump on teh furnace. if so, is its safety switch wired up.
Old 11-26-2012, 10:05 PM   #7
There isnt a condensate pump
Old 11-27-2012, 05:28 PM   #8
Bad compressor, has a handyman hvac guy come check it out, thanks for all the help guys, seriously.
Gas oven possibly thermostat problem... ohman Appliances 7 09-29-2012 09:29 AM
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
Thermostat or oil burner problem? freyguys HVAC 5 02-25-2010 02:44 PM
Changed thermostat and have problem ssmcalister HVAC 3 10-29-2008 05:40 PM
Hunter Thermostat Problem kohlernm HVAC 1 11-22-2007 10:58 PM
