Thermostat Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 03-20-2012, 01:06 PM   #1
Rewards Points: 194
Thermostat Problem
I've been having an odd problem for the last few days with my thermostat. It is a three year old programmable thermostat (not sure of the brand because I'm not at home).
It is scheduled to come on at different times of the day depending on when I typically get home from work and when I typically wake up in the morning. I recently noticed that the thermostat wasn't turning my furnace on - the light on the thermostat said that it was on, but the furnace wasn't doing anything (no blower, no flames - nothing). So, I turned the thermostat off and then on again, and it worked fine.
The problem seems to now happen every time the thermostat goes from "away" to "home" mode or "sleep" to "wake" mode. The thermostat functions normally in between those times.
Does this sound like a thermostat issue? Is it cheaper to just buy a new one instead of trying to trouble shoot the old one?
loftezy is offline   Reply With Quote
Old 03-20-2012, 02:23 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
A supply house will sell a cheap programmable White-Rodgers stat for under $40, more like $32 around here. Home Depot will sell Honeywell for around $70 so per your definiton of cheap I'd possibly buy a new one and switch it. Seeing as how I carry these stock on my truck I'd personally switch it out and see how it runs for a few days / a week and follow up with you if I was the service tech called out to your home.
Tried changing the batteries?
Thanks.
Doc Holliday is offline   Reply With Quote
Old 03-20-2012, 03:16 PM   #3
Rewards Points: 194
I'm ashamed to admit it, but no, I have not tried changing the batteries yet
I'll try that this afternoon!
Old 03-20-2012, 03:38 PM   #4
biggles's Avatar
on that subbase do you see a C terminal and yes the batteries are weak,powerful enought to light the stat but no swing the heat mode with in
Old 03-21-2012, 05:43 PM   #5
Rewards Points: 194
I'm embarrassed to admit this, but I think changing the batteries solved my problem. In my defense, though, the thermostat is supposed to show a "Low Battery" message when the batteries are low.
This might be a low point in my around-the-house-handyman career.
Thermostat for electric baseboard wiring help needed vae_victis HVAC 10 01-05-2012 10:53 AM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
Thermostat or oil burner problem? freyguys HVAC 5 02-25-2010 01:44 PM
Changed thermostat and have problem ssmcalister HVAC 3 10-29-2008 04:40 PM
Hunter Thermostat Problem kohlernm HVAC 1 11-22-2007 09:58 PM
