Thermostat Placement - HVAC - DIY Chatroom Home Improvement Forum
Old 10-24-2010, 07:27 PM   #1
Thermostat placement
Should thermostat for furnace be on wall directly above cold air duct? If not, where should thermostat be placed in a 14 x 22 room with cathedral ceiling with two cold air ducts on inside wall floor?
Thanks.
Clueless2 is offline   Reply With Quote
Old 10-24-2010, 07:49 PM   #2
Rewards Points: 6,652
On the wall that gets the least drafts. That means no fireplace, no cold air returns, no ducts, just a blank wall. That is why the majority of the times, you see thermostats in a hallway on the longest wall between bedrooms.
Old 10-24-2010, 09:25 PM   #3
Thermostats are generally installed near the return grille about 60 inches off the floor.
Artco is offline   Reply With Quote
Old 10-25-2010, 06:42 AM   #4
I have never seen a thermostat near the return grill in all of my life. Mine is no where near one, same with both of my parent's places.
Old 10-25-2010, 07:54 AM   #5
fabrk8r
fabrk8r's Avatar
On an interior wall away from artificial heat sources (TV, stereo, lamp, direct sunlight etc.) away from drafts and doorways and placed approx. 5' from floor. Placement near a return grill is okay because it will get a close to average room temp, *if the return grill is placed properly in relationship to the supply register*
It's best to have the thermostat in a room that is used frequently, otherwise you are defeating the purpose of the thermostat.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 10-25-2010, 12:11 PM   #6
In my opinion, locating it in the most used room, defeats the purpose in creating comfort across the whole house. That will cause that room to either be too warm, or too cool for the rest of the house. Placing it in a common area, such as the hallway is the best solution, or even going with zones is a even better solution.
Thermostat Placement and Blower Speed nitz369 HVAC 6 08-23-2010 01:10 PM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 05:40 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Two Wire 24V Thermostat to Digital Thermostat on Pellet Stove jrodtaclet Electrical 4 09-15-2009 05:37 PM
