Thermostat Or Outside Unit? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-24-2009, 04:03 PM   #1
thermostat or outside unit?
I have a White Rodgers thermostat and a Lennox Elite 13 Heat Pump. The other night, it was very cold in the house and the thermostat had some odd readings (set on 95, temperature showed 65 but it was actually in the 50s) I reset the thermostat the next day and used the emergency heat setting which worked fine. It has since warmed back up (Atlanta weather) Does anyone have any insight into this?
raptor1234 is offline   Reply With Quote
Old 11-24-2009, 06:57 PM   #2
Heat was set on 95? Thermostat still reading 10-15 degrees off? If the thermostat is still off that much replace it. Could be other problems also but start with the simple stuff.
Old 11-25-2009, 06:16 AM   #3
Running
Was the outdoor and indoor units both running ? Did you check them both to see if they were ? They should have if you had the thermostat @ 95 and the house was much colder.
SULTINI is offline   Reply With Quote
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 33 01-30-2014 05:13 AM
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 10:11 AM
Problem with Air Handler wiring connection to Outdoor Unit & Thermostat miamikk HVAC 0 09-29-2009 07:02 PM
central unit will not come on ....please help guyasc HVAC 5 08-24-2008 05:10 PM
Tie-in of a Coleman electric furnace nilo HVAC 9 01-03-2007 03:45 PM
