Thermostat Options - Baseboard + Forced Air - HVAC - DIY Chatroom Home Improvement Forum
Old 06-20-2012, 01:46 PM   #1
Thermostat options - Baseboard + Forced Air
All - I have a heating cooling system composed of 6 zones water baseboard heating and 2 zones forced air cooling. Two of my thermostats are heat/cool, four are heat-only.
I want to replace old non-programmable thermostats with programmable ones, especially the two heat/cool. Questions I have:
1) Will any thermostat work for this? I am looking at the Honeywell RTH7500D 7-day programmable thermostat.
2) Can I put a WiFi thermostat in? How would it get powered/configured?
3) Is there any system that allows me to synchronize the other 4 heating zones? I have an issue with family members touching the heating zones, thinking they are for heat/cool (its a learning process for my family!).
Thanks in advance. First question to the chatroom.
kshatzka is offline   Reply With Quote
Old 06-20-2012, 04:30 PM   #2
MarginallyQualified
Rewards Points: 2,464
is everything based on a 24V control circuit system?
Old 06-20-2012, 08:15 PM   #3
How do I check this? This is my existing thermostat:
http://www.honeywellcentral.com/prod...ermostat-ct87n
Old 06-21-2012, 07:16 AM   #4
MarginallyQualified
How about changing it all to just ONE single thermostat?
For everything?
You mentioned that you had (at least) 6 thermostats.
Are they ALL of that plain vanilla T87 type?
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
Anyone convert their home from forced air to hydronic baseboard? Badfish740 HVAC 3 10-18-2011 10:31 PM
Baseboard Heater Thermostat Ground Wire ? sciron Electrical 6 02-19-2011 05:28 PM
Programmable thermostat for 2-element fan forced heater physh HVAC 0 03-03-2010 06:46 PM
Thermostat is off but first run of baseboard is really hot - HELP! lichris HVAC 7 07-11-2009 10:41 PM
