Thermostat - Old Heat Pump To New Programmable - HVAC - DIY Chatroom Home Improvement Forum
Old 03-03-2013, 08:17 PM   #1
Thermostat - Old Heat Pump to New Programmable
I have a Heat Pump in a condominium. I just changed the old Mercury Honeywell Heat Pump Thermostat similar to T841A or T841A1241 to new Honeywell Programmable Thermostat model RTHL2410C.
The Heat Pump / Air Conditioning unit is
Model No: 49AQ018310BU
Serial No: 2589A15275
I could wire everything but I am confused with additional wires and Heat is not coming on. The old thermostat has Em Heat switch but the new thermostat does not have something like that. The thermostat is working in Cool mode meaning the outside condenser fan is working and the inside blower fan works. Auto/Fan is working as desired, that is the inside blower fan rotates when switched to Fan Mode. Here are the details,
Old Thermostat Wiring
W1 light blue
W2 white
X1 black
G green
Y yellow
R red
O orange
E brown
B vacant
Where do I connect the three additional wires,
W1 blue wire
X1 black wire
E brown wire
I connected from old to new T,
- R to Red wire
- shorted R and Rc with jumper
- G to Green wire
- Y to Yellow wire
- W to White wire
- O to Orange wire
The new thermostat has switch o back, Gas/Oil or Electric/Heat Pump. I made sure to slide to Electric/Heat Pump.
The old T had settings,
EM HEAT -- HEAT -- OFF -- COOL
Another slide witch,
FAN -- AUTO -- ON
LEDs,
Red LED - EM HEAT
Green LED - AUX HEAT
The new thermostat from Honeywell Model RTHL2510 has following terminals,
B -
O -
G -
Y -
W/AUX -
R -
Rc
The manual says, "Wiring for Heat Pumps with Auxiliary or backup heat only"
1. Leave the metal jumper between R & Rc.
2. If your old thermostat had separate O and B wires, wrap B wire in electrical tape and do not connect.
3. If your old thermostat had Y1, W1 and W2 wires, stop now and contact a qualified technician for help.
4. Do not use C or X wire. Do not use B wire if you already have O wire.
5. If your old thermostat had E and Aux wires, connect both wires to Aux terminal.
W1 blue wire
X1 black wire
E brown wire ?
AlexDIY is offline   Reply With Quote
Trane Heat pump - clogged filters cause failure? bigdyl HVAC 2 12-12-2012 03:27 PM
Heat Pump Thermostat Wiring dubosegriffin HVAC 17 11-15-2012 04:05 AM
Heat pump starts initially but will not come back on to maintain temps johnniebravo HVAC 53 11-22-2011 07:48 PM
Wiring New Thermostat for Heat Pump AND Boiler Sweetpea_cmb HVAC 3 10-28-2010 01:29 PM
Programmable Heat Pump Thermostat lwriddle HVAC 1 10-14-2008 03:44 PM
