Thermostat Or Oil Burner Problem? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-17-2010, 12:35 PM   #1
Thermostat or oil burner problem?
I noticed this morning that the house temperature on the thermostat is not equal to the thermostat setting. In other words the heating system (oil fired hot water baseboard) is shutting off before reaching the temp set on the thermostat. The thermostat is a Honeywell RTH7400D programmable. The heating system is kicking on and off periodically and the pipes are warm to the touch throughout the house, it is just staying a degree or two below what it's set on. Pushing the button to temporarily raise the temperature does nothing. Is there a way to know whether this is a thermostat issue or the oil burner has a problem? I can buy and install a new thermostat myself but afraid if it's the oil burner much $$$$ will be involved. Thanks.
freyguys is offline   Reply With Quote
Old 02-17-2010, 03:26 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,396
Buy a Honeywell Focus or Vision Pro at HDepot and install it. Read the install manual and set it for hot water heating.
Old 02-17-2010, 03:29 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 594
Ayuh,... How long has it been since the boiler was serviced by a technician,..?? This season,..??
My guess is, because you're getting Heat, it's probably a control issue,.. T-Stat,.?. Maybe,..??
Old 02-17-2010, 06:17 PM   #4
An old Tradesmen
Rewards Points: 6,462
Or low water pressure.
Look at your boilers gauge. What temp and pressure does it say?
Old 02-25-2010, 01:05 PM   #5
skidrowpete
Rewards Points: 12
been there is putting you on the right track the thermostat just turns the ciculator on and off check pressure and temp readings at boiler
skidrowpete is offline   Reply With Quote
Old 02-25-2010, 02:44 PM   #6
Licensed Master Plumber
does the heat anticipator in the thermostat match the amp setting of the boiler control?
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Carrier 58SXA main burner problem... bfordmn HVAC 5 11-12-2011 10:14 AM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
Replacing thermostat...................... sktn77a HVAC 6 09-02-2009 11:07 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
2 stage heat thermostat problem W1 AND w2 wires whatdoIdonow HVAC 6 11-26-2006 01:04 AM
