Old 07-06-2011, 09:25 PM   #1
Thermostat, no letters
I want to replace a White Rodgers mercury thermostat. I have heat pump AC/heat with two stage heat and 1 stage cool. I called Honeywell for advice on what model to get and they say I need to read off the letters on the t-stat. Well, there are NO letters. I removed the cover and there are 3 wires on the left side and 2 on the right. No letters anywhere near the wire connections. The model is 1F58-94 and I can't find that model White Rodgers t-stat on the web anywhere. the closest I came was 1F58-72 but it is not identical. I was hoping to find the letters on the instructions. The letters are on the wiring diagram for the 58-72 but who knows how similar they are. The house was built in late 2002 so I don't know why the model can't be found online.
Is there any other way to identify the letters for the wires so I can determine a programmable replacement model? The wires have weird colors too. Light blue, tan, yellow.
crickie is offline   Reply With Quote
Old 07-06-2011, 09:32 PM   #2
JJboy's Avatar
you can check the wires colors at furnace board control
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-06-2011, 10:01 PM   #3
Hmmm. Thanks, but I don't know of any furnace board control. The heat pump outside is the only other equipment that I know about.
Did a quick check online and... Would it be behind the metal plate that has the wires on it?
Old 07-06-2011, 10:32 PM   #4
JJboy's Avatar
can you post some pics?
Old 07-06-2011, 10:37 PM   #5
Professional
sounds like you are not down to the sub base. Check for screws holding the stat to the sub base and remove the stat to gain access to the terminals
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 07-07-2011, 07:21 AM   #6
Will do later today. got other commitments this morning. Thanks much. It is 7:20 am where I am.
Old 07-07-2011, 12:31 PM   #7
Willing to listen
Current White Rodgers replacement would be 1F79-111 (non-programable) or 1F72-151 (programmable) in the 70's series product line. You can probably cross to to another brand if necessary....
Done That is offline   Reply With Quote
Old 07-07-2011, 05:57 PM   #8
I want a 5-1-1 or 7 day programmable. Someone told me Honeywell was the best. I don't know. How would I find the equivalent. Am trying to attach photo for JJboy. Hope it works. If not, will try once more.
Old 07-07-2011, 06:33 PM   #9
Trying to send pic, again. In response to JJboy request. Attachment 35017
Old 07-07-2011, 06:35 PM   #10
JJboy's Avatar
Use this site to upload the images==> http://www.imageshack.us/
Old 07-07-2011, 06:58 PM   #11
JJ, I was able to see the pic I posted. If you can't see it, let me know. I just clicked and there it was. I finally learned how to attach it to my post.
Thanks for the other site.
Old 07-07-2011, 07:00 PM   #12
Professional
not able to see it.
IT IS WHAT IT IS
Old 07-07-2011, 07:14 PM   #13
This seems to be the 'long way round' to attach a photo.
I don't know how to get it from the site. If you can't get to it with the 2nd url below, I just give up and stop bothering you folks. Thanks.
http://profile.imageshack.us/user/crickie22/
http://imageshack.us/photo/my-images...rmostatwr.jpg/
Old 07-07-2011, 07:34 PM   #14
Professional
4 slotted screws can be seen in the photo. remove them and pull the thermostat from the sub base to gain access to the terminals
IT IS WHAT IT IS
Old 07-07-2011, 07:35 PM   #15
There's your answer. That stat has 3 layers and you only have one off.
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 05:32 PM
Thermostat issues rathipon HVAC 4 01-29-2011 12:46 PM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 06:40 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
