Old 06-30-2009, 06:13 PM   #1
Default Thermostat from Manual to Digital
I have a 1994 Mobile home that has a Coleman Evcon Presidental ac/heating unit. The thermostat is the same brand (manual). I would like to replace the manual thermostat with a digital Hunter "Just Right" Model 42995b Thermostat, if that is possible. The problem is how to hook it up. My system has 1 rocker button that you switch to heat when you want to use the heater and cool when you want to use the AC. It also has another rocker button for Auto and Continuous. My manual thermostat is only hooked up with two wires. A red one and a white one. There are other colored wires (blue, yellow, green and one other color that I can't remember) that are also present, but they are not hooked to the thermostat in any way, they are just folded down. How do you hook this to the digital thermostat which has a red wire that is folded like the loop in shoe string (one end is attached the Rh screw and the other is hooked to another letter screw that I can't remember). So what do you do with the red and white wire from my old thermostat. Do I use the other colored wires I mentioned earlier with the new digital thermostat or can I just hook it up with the red and white wire.
trinamillersmit is offline   Reply With Quote
Old 06-30-2009, 06:26 PM   #2
An old Tradesmen
You won't be usig that thrmostat with that system.
That system requires the thermostat to be both direct acting and reverse acting.
Digital thermostats are not configured that way.
You would need to rewire the furnace controls, and add a relay or 2.
Old 06-30-2009, 06:50 PM   #3
Thanks Beenthere for the reply. Do you know if I can use another manual thermostat? I just think the thermostat is not working properly.
Old 06-30-2009, 07:18 PM   #4
An old Tradesmen
Yes, you can use most any standard thermostat.
I say your digital won't work.
But, some battery operated ones will work.
If your model is battery operated, try it.
But make sure it works in both heat and cool befoe you dispose of your old thermostat.
Old 07-01-2009, 11:20 AM   #5
Beenthere, thanks again for your post. I just saw it this morning. The digital one that I have is battery operated and like I said in my earlier post. It is not the programmable kind. So, you think it could possibly work. Any idea how you would start hooking it up though since mine only has two wires (I mean two wires that are actually hooked to my old manual thermostat). Like I said earlier, I think my old thermostat is not working properly. It won't shut off even when the room is at what I believe is the desired temperature. However, you can move it up to about 80 or so then it will turn off.
Old 07-02-2009, 11:21 AM   #6
An old Tradesmen
Just hook up the RH and W.
To the same wires that were connected to your old stat.
More On This Topic
Today we are replacing a bad thermostat. Now once you have it removed from the wall, you’ll have to scrape this and repaint it, I’m sure. But you want to make sure to get the right thermostat because you can cause some damage to your A/C or... Read More »
Hello, Reggie Hayes here with Expert Village. Now let?s take a time out for a second and talk about connectors. Pay very close attention because what we cover here is going to be referenced a lot later on when we go to hooking up all these components... Read More »
Hi! This is Blake Whitaker for Expert Village. We are learning about stop motion animation. I'm going to hook up all my digital equipment now step by step. First I am going to plug my 4 pin fire wire cable into my camera. Next I am going to plug the 6... Read More »
Okay the big differences are in the different kinds of digital cameras, the different levels of digital cameras. The consumer cameras don't have manual exposure. That means you can't change the speed, the shutter speed or the aperture like you want. And... Read More »
In this section, we will discuss the major video and audio cables from the lowest quality to the highest. First we have basic speaker wire. In most cases, the wire will have 2 distinct colors; a copper tone and one with a lighter silver color on the... Read More »
Replace Condo's 2 wire mechanical thermostat with digital thermostat kat83 HVAC 4 06-02-2008 05:44 PM
Replace Condo's 2 wire mechanical thermostat with digital thermostat kat83 Electrical 2 05-22-2008 01:52 PM
How to connect a Digital Thermostat (Electric heating) jfgagnon HVAC 0 05-16-2007 10:32 AM
How to connect a Digital Thermostat jfgagnon Electrical 2 05-10-2007 02:01 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
