Thermostat Locked On To A Temp - HVAC - DIY Chatroom Home Improvement Forum
Old 11-05-2006, 10:07 AM   #1
thermostat locked on to a temp
I have a 4 year old Heil 90 Series forced air furnace with a possible problem in the thermostat. It (furnace) is not flashing any fault codes. The blower fan will not run in the auto mode. I ran an ignition start procedure which met with negative results. The thermostat is locked onto a temperature and can not be adjusted. Would this be a thermo?
tdean63 is offline   Reply With Quote
Old 11-05-2006, 04:52 PM   #2
Thoroughbred Mopar Man
Rewards Points: 502
Hi tdean63
It could possibly be a thermostat problem, but to determine that we will need a little more information. What make and series of thermostat do you have. If it is a digital try taking the batteries out of it and letting it bleed down. Let us know and one of us will try and walk you through it.
Good luck
Ruty
#CARRIERMAN is offline   Reply With Quote
Old 11-06-2006, 08:34 PM   #3
thermostat
Had an HVAC tech come out today and they said it was the computer board. They ran a check on thermo and it was fine, so it wasn't that.
Has there been problems on 2004 Heil furnaces (90 series) with the computer boards? Please advise..it doesn't make sense to have that on a new furnace like that.
Old 11-06-2006, 10:09 PM   #4
Rewards Points: 502
Hi tdean63
Do you have the part # for the replacement board? If you do I can find out for you what problems have been incountered. I can also find out rather or not they have addresed it in the newer versions. let me know and I will find out for you.
Rusty
Old 11-07-2006, 09:01 AM   #5
The furnace model is a Heil SN # N9M2100F1481 Manufactured 5/2004.
The circuit board is a honeywell with the following ID number on it ST9160B-1084
Thanks for the help!
Old 11-07-2006, 10:55 AM   #6
Rewards Points: 502
Hi tdean63
I did a little research this morning to see what I could find out. This board would appear to be pretty reliable. Some thing to watch for though, make sure furnace has a good earth ground, make sure water does not get onto the board. The other part of the equation is this is an inexpensive board. Should have cost you around $50.00. If you have to replace it again the part # is 1014460. Hope this helps, have a safe and warm winter.
Rusty
Old 11-07-2006, 11:58 AM   #7
appreciate the research, fortunately it's a warranty part.
we should be up and going this afternoon.
thanks
NOMA Thermostat brobinson68 HVAC 5 01-17-2007 03:36 PM
Lux 722E Thermostat mgkicker HVAC 3 10-27-2006 02:40 PM
Need help "breaking" thermostat! o2bjt HVAC 1 09-08-2006 08:43 PM
