Thermostat Keeps Shutting Off And On - HVAC - DIY Chatroom Home Improvement Forum
Old 06-15-2012, 12:22 AM   #1
Thermostat keeps shutting off and on
My thermostat keeps shutting off and on. Not sure what's wrong with it, but the house is not cooling like it used to. Any suggestions?
LBrooker is offline   Reply With Quote
Old 06-15-2012, 05:05 AM   #2
An old Tradesmen
Rewards Points: 8,174
Float switch doing its job. Check your drains and over flow pan.
Old 07-02-2012, 07:39 PM   #3
okay replaced thermostat and cleared drains. thank you so much for your response! its working okay now. still doesn't feel like it works like it used to but maybe thats because I am in florida where its 96 degrees!
Old 07-02-2012, 08:30 PM   #4
You might want to have it check by a pro. It could also be low on freon or air restriction. It can cause more damage if not corrected.
Mr.HVAC is offline   Reply With Quote
