Thermostat Issues - HVAC - DIY Chatroom Home Improvement Forum
Old 05-31-2011, 06:42 PM   #1
Thermostat issues
I have a totaline thermostat and I have noticed that the temp display keps indicating an increase in inside temp; however the ac unit is running on my heat pump. The temp is set for 72 but in the last few hours the internal temp has increasing been rising, now up to 78 degrees...any thought
theadmiral34 is offline   Reply With Quote
Old 05-31-2011, 06:46 PM   #2
the ac seems to be running fine and putting out cold air...though due to the thermostat issues, it's ben running non-stop
Old 05-31-2011, 07:01 PM   #3
Turn the t-stat off. Open it so where you see the winding connections. Unscrew the red connection and don't let it touch anything for about 3 minutes and put it back turn the tstat back on to auto and cool that will reset the thermostat oh and check the batteries
dallastxtech is offline   Reply With Quote
Old 05-31-2011, 07:25 PM   #4
Rewards Points: 6,652
If you have a thermometer that measures down to 0 to 20 degrees, take the temp at the closes vent to the air handler. Should be around 40 degrees. If you unhook the Y or C from the thermostat and turn the air handler back on, does it start running again?
Old 05-31-2011, 07:59 PM   #5
Compare the thermostat readings to another thermometer. If they read the same then the AC running constantly with the house getting warmer isn't a thermostat issue.
Old 06-01-2011, 02:59 AM   #6
HvacWiz's Avatar
Rewards Points: 252
Explain why you have to take the red t-stat wire off of the subase when the stat is off ? when Just moving it to the off position will break the 24 v.
HvacWiz is offline   Reply With Quote
Old 06-01-2011, 06:47 AM   #7
So tstat will reset and work properly. I have done this before and it works.everytime you want to reset tstat you can do this.
Old 06-01-2011, 06:54 AM   #8
You have posted the same thing over and over. It is not a thermostat issue. Please refrain from copying and pasting info on multiple threads, which does nothing to help the original poster. It only confuses them.
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
Thermostat issues rathipon HVAC 4 01-29-2011 11:46 AM
Programmable thermostat and zone issues bawinnicki HVAC 7 01-10-2011 10:23 AM
New Thermostat issues when cooling guimond777 HVAC 2 05-04-2009 10:46 AM
