Thermostat Issue - HVAC - DIY Chatroom Home Improvement Forum
Old 02-05-2014, 07:30 PM   #1
Thermostat issue
I have a Carrier Infinity 96 HVAC system. This morning the thermostat was blank--no lights or anything.
I pulled the stat and checked for voltage and have no voltage.
I pulled the access panel on the blower unit. The LED is a constant amber. Troubleshooting guide says this means the control circuit is getting 24 volts.
Checked for voltage on the connector that leads up to the thermostat--no voltage.
Does this mean the control panel is bad or can some other error cause the control panel to cut power to the stat?
chimebowl is offline   Reply With Quote
Old 02-05-2014, 07:48 PM   #2
OK, now I feel silly--I found the problem! This unit has a condensate pump and the pump hung up. The reservoir filled up and shut the unit down. I jiggled loose the float in the pump chamber and it drained the reservoir--problem solved.
I had not realized that this would shut down the thermostat or I would have tried it first.
(I hate condensate pumps, by the way.)
Old 02-05-2014, 08:18 PM   #3
An old Tradesmen
Rewards Points: 8,144
They have their place.
The float hanging up, probably means its time to clean the condensate pump's tank.
Hydronic heating thermostat issue DIbrYan HVAC 4 01-11-2014 09:13 PM
Thermostat Issue wherespete HVAC 38 04-10-2012 09:17 AM
Thermostat Problem loftezy HVAC 4 03-21-2012 05:43 PM
Need help replacing an OLD General Controls Thermostat ohman HVAC 3 06-08-2011 05:35 PM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
