Thermostat Issue - HVAC - DIY Chatroom Home Improvement Forum
Old 11-28-2011, 11:11 PM   #1
Thermostat issue
Model: Lux TX9000TS
Last night at midnight I woke ip to override the temp. The display unit shut off and then turned back on after 30 sec. When it came back in the override temp was set at 45 degrees! It would not allow me to change it....period. After an hour tried again and it allowed me to change the temp. Today I changed the battery. Other than that should I be worried?
dinosaur1 is offline   Reply With Quote
Old 11-28-2011, 11:34 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
If it happens again with new batteries, then worry.
Doc Holliday is offline   Reply With Quote
Old 11-29-2011, 06:59 PM   #3
So far so good
The Following User Says Thank You to dinosaur1 For This Useful Post:
Doc Holliday (11-29-2011)
Replacing old Honeywell thermostat with new Honeywell thermostat optimizer HVAC 13 04-20-2011 06:22 PM
Installing New thermostat need help effusion_01 HVAC 18 03-01-2011 05:09 AM
Is it my furnace or my thermostat? Blows cold and can't shut it off TrilliumLady HVAC 6 12-16-2010 06:51 PM
double pole thermostat for kickspace heater lee12 Electrical 3 12-09-2010 12:52 PM
connecting a 4 wire SP thermostat to a 2 wire system wiichkin Electrical 4 08-15-2010 01:35 PM
