Thermostat Install Without C Wire - HVAC - DIY Chatroom Home Improvement Forum
Old 06-15-2015, 03:25 PM   #1
Rewards Points: 129
Thermostat install without C wire
I'm trying to install a Honeywell RTH6500WF thermostat. I have no C wire. I thought I would be OK after watching the Honeywell video on alternate installation. The wiring coming out of the wall had an extra, unused wire. I checked the terminal block in the furnace and saw that same wire there, still unused. Looking good, I thought. Then I saw the furnace had no terminal marked C. All of the terminals already had wires attached. I called Honeywell, sat on hold for 20 minutes, and got told to call the furnace manufacturer, Lennox, to see if they label the C or common wire something else. I called Lennox, sat on hold for 20 minutes, and got told that they won't discuss such matters with anyone but an HVAC repair person. The next, logical thing for me to do was to come here and ask for help.
The furnace is a Lennox Pulse made in the 1980's. I think the model might be G14 series? The terminals are labeled R, W, Y, G, T. I'll try to attach a photo below.
As usual, any suggestions will be appreciated.
bucksone is offline   Reply With Quote
Old 06-15-2015, 03:35 PM   #2
HVAC Tech/Owner
Rewards Points: 604
Should have bought a new furnace instead of a thermostat
Technow is offline   Reply With Quote
Old 06-15-2015, 03:35 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,090
T is C on that furnace. T = transformer, common side. That furnace should have the heat exchanger pressure tested by a Lennox Pro. Most of those furnaces have been replaced due to cracked heat exchangers and some of the parts are obsolete.
Old 06-15-2015, 03:37 PM   #4
Hvac Pro
yuri's Avatar
It was a VERY good albeit noisy furnace. I replaced Mom`s because some parts are obsolete.
Old 06-15-2015, 03:56 PM   #5
Rewards Points: 129
So, if I attach that unused wire to the T terminal on the furnace and attach the other end to the C terminal on the new thermostat, I should be good to go?
A new furnace sounds great! This one still works, however, and I don't have the extra money to replace a working appliance.
Old 06-15-2015, 04:26 PM   #6
Hvac Pro
yuri's Avatar
Yep it will work. Doubt that furnace will last long and when it breaks down you may not get some critical parts for it or any experienced techs. Most have retired as that furnace came out in 1980 and is VERY specialised in how it works.
People have got CO poisioning from them when the heat exchanger cracks. Lennox rexcommends they be pressure tested every 5 years. They can have complete failures where the exhaust pipe breaks off the top of the heat exchanger. Not a furnace I would want anymore and I sold hordes of them. Got rid of Mom's for those reasons.
Old 06-15-2015, 05:23 PM   #7
Rewards Points: 42
I have been told that were awesome units when they worked well. Bit noisy though. Apparently though many techs didn't know how to work on them and many failed prematurely. I've only ever worked on one. The company that went in after us replaced a perfectly working unit because they didn't know how to work on it. Good luck. Hopefully nothing goes wrong with yours. You probably won't find much help if something does.
Cheers!
supers05 is online now   Reply With Quote
Old 06-15-2015, 05:27 PM   #8
Rewards Points: 1,989
If they are prone to leaks , install a carbon monoxide detector near the furnace .
God bless
Wyr
WyrTwister is offline   Reply With Quote
Old 06-15-2015, 07:59 PM   #9
Rewards Points: 129
Success! I got the thermostat installed and up and running.
Good advice on the carbon monoxide detector. I have one on the second floor, but I'll get one for the basement as well.
Thanks for all of the help.
The Following User Says Thank You to bucksone For This Useful Post:
supers05 (06-16-2015)
I need help wiring my thermostat. batalbj1 HVAC 3 03-28-2013 11:30 PM
Replace 3 wire electric baseboard thermostat Bhurl5 HVAC 4 11-27-2011 09:07 PM
Thermostat Install Help funny wire jhare215 HVAC 15 01-05-2011 10:11 PM
Replace Condo's 2 wire mechanical thermostat with digital thermostat kat83 Electrical 2 05-22-2008 12:52 PM
X wire on old thermostat Jellybean HVAC 3 03-30-2008 08:14 AM
