Thermostat Install Help Funny Wire - HVAC - DIY Chatroom Home Improvement Forum
Old 01-05-2011, 07:26 PM   #1
Thermostat Install Help funny wire
I am installing a new Honeywell digital thermostat from an old analog one. On the old analog thermostat there is a wire labeled A along with G RC W Y RH(connected to RC). There is no A on the new thermostat where do I connect it or connect it at all ?
The New thermostat has the following labels connectors: Y G RH RC W
Thanks for all your Help
jhare215 is offline   Reply With Quote
Old 01-05-2011, 07:37 PM   #2
An old Tradesmen
Rewards Points: 8,192
What is the thermostat connected to.
Old 01-05-2011, 07:39 PM   #3
Not sure I get what you mean. The old thermostat is connected to the wires still. The new one is not connected to anything. I talking about connecting the wires. I don't know what the A wire is or were to connect it on the new themostat
Old 01-05-2011, 08:09 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
you probably don't connect it to the new stat. but he was asking what equipment you have and if you have checked inside your furnace or air handler what the A wire connects to there. DO you have a heat pump, boiler, gas furnace?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 01-05-2011, 08:12 PM   #5
No Its an electric furnace and the old stat has six wires and the new stat only has a place for 5. and the odd wire is labled "A". So should I just cap it off. Sorry about the confusion. and thanks
BTW I haven't looked at the inside of my unit
Old 01-05-2011, 08:15 PM   #6
AKA HVACTECHFW
is it electric only furnace, no heat pump? Can you post a pic of old stat?
IT IS WHAT IT IS
Old 01-05-2011, 08:18 PM   #7
one second I think i can
Old 01-05-2011, 08:20 PM   #8
Go look and see what the other end of the wire is connected to.
Old 01-05-2011, 08:30 PM   #9
here its a rough picture took it on a cell phone maybe you can see something
http://tinypic.com/r/15s4nkn/7
The brown wire is labeled yellow
and the yellow is the wire that is marked A
Old 01-05-2011, 08:38 PM   #10
AKA HVACTECHFW
i agree open furnace door and see what A is attached to
IT IS WHAT IT IS
Old 01-05-2011, 08:44 PM   #11
the wires are not even the same color inside the unit. I have no idea. Could you tell something from the picture its a clickable link.
Old 01-05-2011, 08:49 PM   #12
AKA HVACTECHFW
do you have a model of old stat or name brand?
IT IS WHAT IT IS
Old 01-05-2011, 08:53 PM   #13
White-Rodgers
heating- .15-1.2 AMP
Cooling-1.5 AMP MAX
Max 30 volts
Type 1F56W-444
Class 2
That is what it says verbatim off the old stat
Old 01-05-2011, 09:04 PM   #14
AKA HVACTECHFW
SPECIAL SYSTEM CONFIGURATIONS
Electric Heat Furnaces (Single Transformer Systems
Only)
The subbase as shipped may not operate the fan correctly.
If both the heating and cooling system must operate
the fan relay, remove the yellow factory-installed
jumper wire from the Y terminal and connect it to the A
terminal. The fan should now cycle when the thermostat
calls for either heat or cool.
tape up A and don't use. set new stat to electric heat so it controls fan in heating and cooling
IT IS WHAT IT IS
Old 01-05-2011, 09:07 PM   #15
Thank You very much I will tape up A and hook up everything else like normal. SO just out of curiosity what does the A do ?
Tags
install , thermostat
Progammable Thermostat Common Wire 72 Z27 HVAC 1 07-06-2010 05:55 PM
3 wire thermostat shadow82399 HVAC 3 09-20-2009 07:37 PM
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
Thermostat wiring advice tsugacanadensis HVAC 2 11-04-2008 07:04 AM
8 wire to 4 wire thermostat help needed dj petey HVAC 5 04-15-2006 12:20 PM
