Thermostat Idiot - HVAC - DIY Chatroom Home Improvement Forum
Old 05-05-2013, 07:37 AM   #1
thermostat idiot
Our boiler provides heat and hot water. If I turn off the thermostat to kill heat in warm weather, will the boiler also stop providing domestic hot water?
Laugh all you want, I can take it. Thanks.
kentannenbaum is offline   Reply With Quote
Old 05-05-2013, 07:57 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,092
Did you have hot water last year when you did that?
No it won't as it has a temp control for the hot water tank to turn on the burner and circ pump for the tank. Have not seen one as we don't have them here but that must be the way they work. Stay tuned for the guys who have seen them.
Old 05-05-2013, 07:58 AM   #3
REP
No , if the water heater has an aquastat that will bring on the boiler for hot water.Just don't throw the circut breaker to off as then you will be taking cold showers.
REP is offline   Reply With Quote
Old 05-05-2013, 09:55 AM   #4
An old Tradesmen
Rewards Points: 6,068
Boilers with tankless coils or indirect water heaters are set up to provide hot water weather or not its the heating season. And the thermostat has no control over it making hot water.
Old 05-05-2013, 11:55 AM   #5
Experienced HVAC Tech
HVAC1000's Avatar
Your water heater is essentially another zone in your house so as long as that zone calls for heat the boiler will provide same as any other zone
HVAC1000 is offline   Reply With Quote
Old 05-07-2013, 08:37 PM   #6
biggles's Avatar
the boiler is it steam and or hot water with a circ pump?it maintains the hot water to a usable temp for the showers and sinks,but not to heat the house.might notice the water is hotter in the winter then the summer...that is the controller that runs the domestic water heating cycle within the boiler
I need help wiring my thermostat. batalbj1 HVAC 3 03-28-2013 11:30 PM
Thermostat Replacement kgreen4me Electrical 2 01-27-2013 12:46 PM
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
Thermostat for electric baseboard wiring help needed vae_victis HVAC 10 01-05-2012 11:53 AM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 05:32 PM
