Thermostat Help Needed - HVAC - DIY Chatroom Home Improvement Forum
Old 08-04-2009, 12:01 PM   #1
Thermostat help needed
maybe someone can help me. I have an older Heil split system A/C heat pump.
Tried to install new thermostat from an old manual (mercury) to a digital. I can't get the A/C to come on.
I went to the attic and found these wires connected to the air handler.
Red to R
Blue to C
Yellow to Y
Green to G
Orange to O
White to W1 and W2 (jumped)
I took a picture of the previous thermostat wiring so I would remember how it was hooked up. PROBLEM picture was deleted now I am unsure. All of the above wires were in use at the thermostat the white wire at the thermostat was stripped in two places and connected to two terminals.
there is a optional jumper on the new Honeywell digital thermostat between Y and W1.
I think it is the white wire that is giving me problems.
I have hooked up the following
red to R
Blue to C
Green to G
Yellow to Y
Orange to O
beyond this I am unsure........jumper or no jumper? White Wire where?
rjkleiner is offline   Reply With Quote
Old 08-05-2009, 06:46 AM   #2
What Honeywell model are you trying to wire up, and what was the old mercury tstat?
dac122 is offline   Reply With Quote
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
thermostat type needed with temp-a-trol MSC-3 joe c HVAC 1 06-13-2008 06:12 PM
8 wire to 4 wire thermostat help needed dj petey Electrical 5 01-19-2008 09:11 AM
Odd Thermostat set-up, help needed Dan1 Electrical 3 10-08-2007 11:12 AM
8 wire to 4 wire thermostat help needed dj petey HVAC 5 04-15-2006 12:20 PM
