Thermostat Height - HVAC - DIY Chatroom Home Improvement Forum
Old 12-06-2009, 08:14 PM   #1
Thermostat height
I am in the middle of removing old wallpaper in the living room and getting ready to paper again but with a wainscoat this time. The wife would like the thermostat for the boiler lowered on the wall due to a mirror she may want to hang The thermostat is presently centered at 4' 7" but the instructions that came with the new one said put at 5 feet.
Can I assume that if I lower the height a little I just might have to compensate my settings lower to keep the average temperature in the room the same as now? I personally would like to keep it where it is height wise and it will not be moved any to the left or right
meboatermike is offline   Reply With Quote
Old 12-06-2009, 09:10 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,454
Should not make that big of a difference. New electronic tstats are accurate to 1 degF anyway. Check the programming and set it for hot water heat. By default it is usually set for forced air gas heat.
Old 12-06-2009, 09:12 PM   #3
An old Tradesmen
Rewards Points: 6,576
You can lower it some, and not really notice any change in room temps.
ADA is 44"
Old 12-06-2009, 09:48 PM   #4
thermostat height
thank you
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 04:29 AM
Two Wire 24V Thermostat to Digital Thermostat on Pellet Stove jrodtaclet Electrical 4 09-15-2009 06:37 PM
Replacing thermostat...................... sktn77a HVAC 6 09-02-2009 11:07 PM
Thermostat from Manual to Digital trinamillersmit HVAC 5 07-02-2009 10:21 AM
