Thermostat For Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 11-08-2009, 11:50 AM   #1
Thermostat for Heat Pump
Having a problem with getting new thermostat to work, my wife wanted a simple thermostat so I changed it. I had Honeywell 32207415-0299948 7 day programable. I boght from Grainger a White Rodgers 1F80 361, it is a 4 wire system. When I hooked every thing up just like before I can now only get AC only. HELP?????
okieinarizona is offline   Reply With Quote
Old 11-08-2009, 11:55 AM   #2
GC/Master Plumber/Mech
Rewards Points: 560
what were the terminal connection on the old stat?
what are the terminal connections on the new stat?
If this is a heat pump then you need more than 4 wires
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 11-08-2009, 12:00 PM   #3
Heat Pump
Wiring is
Red - Rh
Yellow
White
Green
Red has jumper from Rh to Rc
Old 11-08-2009, 12:07 PM   #4
Rewards Points: 560
Originally Posted by okieinarizona View Post
Wiring is
Red - Rh
Yellow
White
Green
If this is the new stat it is not for a heat pump you need an "O" terminal too
What are the terminals on the old stat?
Old 11-08-2009, 12:15 PM   #5
Thermostat
The wiring on the old one were the same, I had someone tell me to put a jumper from greem to yellow and it didnt help still only a/c.
There are only 4 wires
Old 11-08-2009, 12:19 PM   #6
Rewards Points: 560
Jumping the G/Y makes the fan come on when there is a call for a/c.
Are you 100% sure you have a HP
Old 11-08-2009, 12:24 PM   #7
Houston204's Avatar
Rewards Points: 556
I've seen 4 wire stats connected to geothermal heatpumps. The white was for the reversing valve. O or B would be the next question. Probably B.
If you don't remember where white was, post the make and model of your heatpump.
If this is not a heatpump, it probably must be set for electric heat.
Houston204 is offline   Reply With Quote
Old 11-08-2009, 12:39 PM   #8
Houston204's Avatar
Rewards Points: 556
This thermostat is configured from the factory to operate a heat/
cool, fossil fuel (gas, oil, etc.), forced air system. It is configured
correctly for any system that DOES NOT require the thermostat
to energize the fan on a call for heat. If your system is an electric
heat or heat-pump system that REQUIRES the thermostat to
turn on the fan on a call for heat, locate the ELECTRIC/GAS
switch on the back of the thermostat (see fig. 1) and switch it to
the ELECTRIC position. This will allow the thermostat to
energize the fan immediately on a call for heat.
Old 11-08-2009, 02:30 PM   #9
An old Tradesmen
Rewards Points: 8,194
Post the brand and model of you heat pump, and air handler.
Old 11-08-2009, 09:01 PM   #10
If it's a rheem/ruud heat pump put white on B .Add a jumper wire between y and w terminals.
Most other brands of heat pump put the white on o. Still need the jumper between y and w
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
carrier infinity 50Xt packaged heat pump with infinity thermostat mguillen HVAC 12 12-05-2011 01:42 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 06:10 PM
programmable thermostat + heat pump Potomac101 HVAC 10 12-03-2008 10:02 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
