Thermostat Has No Display - HVAC - DIY Chatroom Home Improvement Forum
Old 08-08-2011, 02:01 PM   #1
thermostat has no display
Came home and thermostat on bottom floor was completely out. I have a honeywell t8001 thermostat and it does not use batteries. I went to fuse box and saw that fuse was tripped. I reset fuse and thermostat still had no display. I went up stairs and removed the thermostat upstairs and replaced it with the 1 from downstairs and the thermostat was working fine. I took both thermostats downstairs and they have no display. Upstairs they work fine.
-any thoughts
Ruud Furnace, not sure what model.
theincrediblejc is offline   Reply With Quote
Old 08-08-2011, 02:20 PM   #2
Rewards Points: 6,652
model number would be on the plate inside the door, where the burners are.
Old 08-08-2011, 08:20 PM   #3
customer.honeywell.com/techlit/pdf/PackedLit/69-1432.pdf
hope this helps...
SAMCRO is offline   Reply With Quote
Old 08-08-2011, 08:44 PM   #4
Are there two seperate systems or is this a zoned unit?
Master of Cold is offline   Reply With Quote
Old 08-09-2011, 06:23 AM   #5
Rewards Points: 1,216
Sounds like a control transformer fuse or burnout.
COLDIRON is offline   Reply With Quote
Old 08-09-2011, 06:45 AM   #6
Thank you guys for your assistance.
I'll list the model as soon as I get home to check it.
Master of Cold, It is 2 separate systems.
Coldiron, how can i check the "control transformer fuse"?
Old 08-09-2011, 08:01 AM   #7
biggles's Avatar
fuse is on the control board withingn the furnace or a CB on the tr itself for the 24V side...jump R to G see if the fan runs on the bottom floor subbase if you have a dugital check R to C also on the sub for a constant 24Vs
Old 08-09-2011, 01:25 PM   #8
Check the float switch in the drain. Pull it out and see if the thermostat comes back on.
Old 08-09-2011, 03:58 PM   #9
Is this an attic job? Maybe there is no float switch.
Old 08-09-2011, 04:00 PM   #10
ColdIron, I never knew that a attic is under the bottom floor. To back things up, the unit they are having problems with, is the downstairs or first floor unit, not the one on the upper floor.
Old 08-09-2011, 04:04 PM   #11
Thanks for the backup that's why I asked the question the dude before me referenced a float switch.
Old 08-09-2011, 04:20 PM   #12
Because the "dude" before, did not read the whole thread. We seemed to have lost the OP, so hopefully this weekend, we may know the outcome of why the first floor thermo stopped working.
Old 08-09-2011, 04:27 PM   #13
An old Tradesmen
Rewards Points: 6,914
Are you sure the new fuse didn't blow already?
Old 08-09-2011, 04:30 PM   #14
Good question been usually when one blows the second one is right behind it if the problem is not identified.
Old 08-09-2011, 04:42 PM   #15
Hey guys, thanks for all the help. Yes the furnace is in the attic. The furnace is a Ruud silhouette gas furnace model # ugp-j-05eaver. Is there a float on furnace's in the attic?
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
NOMA/Garrison thermostat - Display Problem caper26 HVAC 3 10-30-2011 03:09 AM
Totaline thermostat model p374-1700 display led is not turning on SLMEZY HVAC 1 03-08-2011 04:17 PM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
Thermostat issues rathipon HVAC 4 01-29-2011 11:46 AM
