Thermostat/Furnace/ And A/C Unit - HVAC - DIY Chatroom Home Improvement Forum
Old 06-29-2011, 12:23 AM   #1
Thermostat/Furnace/ and A/C unit
just attempted to install honeywell 6300 thermostat. connected the G W Y R wires and left the blue alone. But now a 24 code is flashing on the furnace. And the thermostat isn't working. Any suggestions?
dmetz06 is offline   Reply With Quote
Old 06-29-2011, 05:17 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,826
check the error code legends on the back of one of the doors. code 24 on a carrier may mean blown fuse on the circuit board and improper or shorted wiring. did you have a problem B4 changing the tstat?
Old 06-29-2011, 06:45 AM   #3
biggles's Avatar
verify on the install info if you need the C connection off the furnace transformer at the subbase...if the stat is lit with no action calling stuff in it needs the C
