Thermostat To Fan Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 10-12-2008, 08:41 PM   #1
Thermostat to fan wiring
I'm trying to wire a normal house fan to be controlled by a ritetemp thermostat and can't figure out which wires go where.
skydive_us is offline   Reply With Quote
Old 10-12-2008, 08:45 PM   #2
Electrical Contractor
kbsparky's Avatar
Your link provided a whole list of available models. Which one do you have, and have you clicked the link for wiring assistance?
Old 10-12-2008, 08:50 PM   #3
tk03's Avatar
Rewards Points: 150
The "G" terminal on the thermostat subbase is usually fan.
tk03 is offline   Reply With Quote
Old 10-12-2008, 08:50 PM   #4
The link works for me (Safari) but it's the 6008 model. I have looked at the instructions many times but it doesn't show how to wire a common household fan, only HVAC units.
I had the 6004 model but it only works for heaters and I just need mine for cooling. The wires for it didn't have R, RH, RC, W.....etc just line and load.
Old 10-12-2008, 08:56 PM   #5
kbsparky's Avatar
IF your old thermostat had "Line" and "Load" terminals on it, then it was probably a line voltage unit. The 6008 model is a different type, that usually operates on 24 Volt systems, and only controls relays that do the actual switching.
These are not compatible, and you need to return it for a line voltage unit.
Old 10-12-2008, 09:19 PM   #6
kbsparky's Avatar
It would appear that none of the thermostats listed on the site you referenced will work with your application.
Here is an alternate site for line voltage cooling thermostats.
Model LV3 might be a good choice.
Honeywell Thermostat Wiring Differences DavidHwang HVAC 16 01-28-2012 02:11 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
Thermostat Wiring Problem crazy woman HVAC 2 08-15-2006 09:22 AM
