Thermostat "FAN ON" Not Working (pictures Of Wiring) - HVAC - DIY Chatroom Home Improvement Forum
Old 06-21-2012, 12:15 AM   #1
Thermostat "FAN ON" not working (pictures of wiring)
Something here has to be missing from the wiring.
Thermostat functions as expected in both heating and cooling while in AUTO mode. With this hot whether the A/C is constantly running and the downstairs is freezing in split level basement.
I would like to save some money since the home is 4000 sq ft and my A/C is only rated at SEER 10 and run the FAN only.
What is wrong with this wiring? (Right middle screw letter is blocked, it has a "B" next to it)
Thank you!!!
ttowngremlin is offline   Reply With Quote
Old 06-21-2012, 12:32 AM   #2
REP
I can't see.Do you have a wire connected to the "Y" terminal?what does the relay at the furnace look like.Is it a fan center or is it a circut board???
REP is offline   Reply With Quote
Old 06-21-2012, 01:17 AM   #3
There is a black wire going to the "Y" terminal.
Sorry about this picture...not really sure what I'm taking a photo of here --- I just know the wires are coming here.
Old 06-21-2012, 03:02 AM   #4
REP
OK you have a circut board.If you look at the circut board you will see a green wire attached.That green wire has to be attached to the "G" terminal on the thermostat.
Old 06-21-2012, 07:52 AM   #5
biggles's Avatar
runnng that fan only isn't going to cool the house just push the heat around from room to room.keep any sunlight from hitting the windows sills and or walls and floors,run ceiling fans if there...and in the real hot days run the system COOL/FAN/ON that will cycle some of that colder LL air back up top.might want to cheat those LL registers to get more air up top.does the LL have a return grill to the furnace/air handler.green wire is there need to land it on G as said..quick test jump R to G for fan on as if you switched it from the subbase..just to verify that mode
Old 06-21-2012, 08:27 PM   #6
Thanks for the tips.
After looking around the lower level, I have realized there are NO INTAKES on the lower level.
This defeats the purpose I had for getting this to work.
Is it unadvised to shut off all the lower vents or will this hurt the system? I could also possibly install a shutoff type valve that distributes air to the lower level.
Will this over-stress the air handler though?
Thanks all for the replies!
Old 06-22-2012, 05:40 AM   #7
biggles's Avatar
if you can tap into the return(piece of flex) and add a retangular grill(wall mount)to pull return from the LL.then cheat down all the grills on the supply on that LL and the return pull will move air and not chill out uncontrolled with the stat up stairs..cheating that LL will push the air up into the main floor
Thermostat for electric baseboard wiring help needed vae_victis HVAC 10 01-05-2012 10:53 AM
Help Wiring Programmable Thermostat Brio9 HVAC 4 02-13-2011 11:25 PM
Thermostat to Controller Wiring Molson HVAC 1 07-05-2010 06:24 PM
Thermostat Heat Pump Wiring difficulties akg4y HVAC 8 04-15-2010 05:16 AM
Unexpected wiring found on existing thermostat mportobello HVAC 12 03-30-2010 06:11 AM
