Thermostat Doesnt Have Power - HVAC - DIY Chatroom Home Improvement Forum
Old 02-07-2012, 11:20 AM   #1
Thermostat doesnt have power
I was trying to install a programmable thermostat. I couldnt get it to turn on. I ended up putting the old one back in place and now this one isnt working either. The display screen doesnt light up. The power is back on but still nothing. I believe i put all the wires back in place. I see in othe rposts white is usually heat, i dont have a white wire but have a brown? Any ideas?
devin21 is offline   Reply With Quote
Old 02-07-2012, 11:30 AM   #2
I'm Your Huckleberry
Rewards Points: 2,270
did you turn the power off to the furnace before working on the stat? if not you probably blew the fuse on the control board or the transformer is shot.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 02-07-2012, 12:31 PM   #3
biggles's Avatar
if you have to LEDs on the new one or can't get FAN/ON from the subbase switch...TR is shot. remove the stat jump R to G for supply fan...if nothing the 24V is burnt or blew a control board fuse.
Old 02-07-2012, 01:26 PM   #4
yeppers
hvac5646 is offline   Reply With Quote
Old 02-07-2012, 03:39 PM   #5
Ron Paul 2012
Sounds like the fuse. I changed a t-stat a couple months ago for my properties RHU and thought nothing of changing the t-stat with the power on. I went up to the roof dreading the worse and found the fuse blown, replaced and was good to go!
HandymanCA is offline   Reply With Quote
Solar at the cottage? Tito1800 Home Theater 2 01-18-2012 03:30 PM
Thermostat Issues sundh Electrical 5 12-11-2011 01:13 AM
backup power to thermostat? 6burgh HVAC 1 11-28-2011 07:14 PM
Need help replacing an OLD General Controls Thermostat ohman HVAC 3 06-08-2011 06:35 PM
No Power to Thermostat Vito HVAC 9 12-14-2008 10:51 PM
