Old 08-04-2012, 09:22 PM   #16
An old Tradesmen
Thermostat to control two systems?
Originally Posted by stickboy1375 View Post
but if your heat loss is too great, you'll never heat your house either.
Thats why on boiler set ups, I make it so both can run at the same time. Saves money on oil.
Old 08-04-2012, 09:43 PM   #17
E2 Electrician
stickboy1375's Avatar
Thats a nice feature, I have a furnace, so I dont have that option. It's either one or the other, im guessing it has to to with head pressure? not being able to remove the heat from the heat pump?
I wasnt 100% sure the OP had a boiler, but I think I would modify my drawing a bit, and install a two stage t-stat to kick the boiler on only when necessary, and still keep the heat pump running... fun part of drawing diagrams.
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 09:43 AM
New thermostat - No coil control Gigs HVAC 5 02-15-2011 09:47 PM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 06:40 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Can't turn furnace fan on from thermostat control cnnd2010 HVAC 0 06-18-2010 11:37 AM
