Old 07-07-2010, 10:27 AM   #1
Thermostat clock runs fast
We have a Totaline P474-1050 thermostat in our condo unit and noticed the clock runs like it's on crack. The minutes change after 60 flashes of the colon, but it's considerably faster than 60 seconds, hence the clock will be hours off after several hours.
We don't currently use the timed functions of the thermostat, so in that regard this is minor, but hope this isn't indicative of something worse than just a fast clock…
Your thoughts?
yankeeNH is offline   Reply With Quote
Old 07-07-2010, 02:09 PM   #2
It was a dark and stormy
Yoyizit's Avatar
There may be a little adjustment wheel somewhere marked with a + and a -. Turn it toward the -.
This is assuming the clock is crystal-controlled rather than using the 60.000 Hz as a timing pulse.
Old 07-07-2010, 06:00 PM   #3
An old Tradesmen
Check voltage to the thermostat. If its 30 or less. Then either you have a harmonic problem(line voltage wire running parallel tot eh low voltage wire) or a bad thermostat.
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 06:40 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
Two Wire 24V Thermostat to Digital Thermostat on Pellet Stove jrodtaclet Electrical 4 09-15-2009 06:37 PM
Thermostat from Manual to Digital trinamillersmit HVAC 5 07-02-2009 10:21 AM
ac/furnace runs whatever thermostat settign donbohn HVAC 1 06-20-2009 06:42 AM
