-   -   Thermostat clock runs fast (http://www.diychatroom.com/f17/thermostat-clock-runs-fast-75610/)
yankeeNH 07-07-2010 09:27 AM
We have a Totaline P474-1050 thermostat in our condo unit and noticed the clock runs like it's on crack. The minutes change after 60 flashes of the colon, but it's considerably faster than 60 seconds, hence the clock will be hours off after several hours.
We don't currently use the timed functions of the thermostat, so in that regard this is minor, but hope this isn't indicative of something worse than just a fast clock…
Your thoughts?
Yoyizit 07-07-2010 01:09 PM
There may be a little adjustment wheel somewhere marked with a + and a -. Turn it toward the -.
This is assuming the clock is crystal-controlled rather than using the 60.000 Hz as a timing pulse.
beenthere 07-07-2010 05:00 PM
Check voltage to the thermostat. If its 30 or less. Then either you have a harmonic problem(line voltage wire running parallel tot eh low voltage wire) or a bad thermostat.
