Thermostat Change Help Needed - HVAC - DIY Chatroom Home Improvement Forum
Old 02-01-2010, 08:24 AM   #1
Thermostat change help needed
I just purchased a house that has a Bard heat pump with a manual Bard thermostat. I have purchased a Honeywell Vision Pro 8000 model TH8321U1006 programable to replace the Bard, when I started to do the change I ran into problems with wire colors to terminals.
Bard Wiring:
Terminal Wire color
G Green
L Black
R Red
X1 Orange
X2 Orange jumper between X1 & X2
B White
Y Yellow
W2 Blue
Honeywell terminals for heat pump
Y2
L
E
AUX
S1
S2
RC
R
O/B
Y
G
C
What color wire to terminal should I use with the Honeywell?
USNRET is offline   Reply With Quote
Old 02-01-2010, 07:04 PM   #2
An old Tradesmen
Rewards Points: 7,344
Would help to know what the wires were connected to at the air handler.
Old 02-01-2010, 09:26 PM   #3
Houston204's Avatar
Rewards Points: 556
http://www.bardhvac.com/digcat/volum...100-409(A).pdf
I'd have to wonder about proper emergency heat operation.
What is your heat pump model number?
Houston204 is offline   Reply With Quote
Old 02-01-2010, 09:37 PM   #4
Houston204's Avatar
Rewards Points: 556
The addition of a dpdt relay would allow your new stat to work. (If your unit also requires B and W2 energized with E and G for emergency heat)
Old 02-02-2010, 12:24 PM   #5
Outdoor unit Mod: 24HPQ2
Indoor unit Mod: B24EHQ1
At indoor unit terminal block it is wired
orange to c
green to g
red to r
yellow to y
white to b
blue to w2
brown to e
black to l
Old 02-02-2010, 12:27 PM   #6
I just realized that I left out "Brown to E" on my first post.
Thank much for your help.
Old 02-02-2010, 06:11 PM   #7
Houston204's Avatar
Rewards Points: 556
Your air handler manual...
http://www.bardhvac.com/digcat/volum...100-069(K).pdf
Heat pump manual...
http://www.bardhvac.com/digcat/volum...100-006(C).pdf
New terminal = Wire (Refer to outer terminal labels on new stat)
L = black
E = brown
Aux = blue
Rc & R = red
O/B = white
G = green
C = orange
option 170 = 7
option 190 = 1
Thermostat help needed rjkleiner HVAC 1 08-05-2009 06:46 AM
thermostat wiring sourmash HVAC 1 07-18-2009 10:17 PM
thermostat wiring sourmash Electrical 1 07-18-2009 04:47 PM
Need to change my electrical panel? 2nd opinion needed I_have_questions Electrical 60 01-30-2009 09:38 AM
Odd Thermostat set-up, help needed Dan1 Electrical 3 10-08-2007 11:12 AM
