Thermostat Change - HVAC - DIY Chatroom Home Improvement Forum
Old 10-01-2009, 05:41 PM   #1
Rewards Points: 152
Thermostat Change
Just bought a new house, the old owner passed away so don't have much info on the system.
Runs an electric forced air furnace (American Standard TWE036xxxxxx) and a seperate air conditioner.
Controlled by a Sears brand thermostat (C387-xxxxx).
It looks to have 6 wires coming through the wall, from what I've read, this is probably a multi-stage furnace/thermostat?
The thermostat is connected as follows:
W1 - white
W2 - black
Y1 - yellow and red (2 seperate wires)
RH - red (jumpered to C)
C - red (jumpered from RH)
G - green
I found a Honeywell programmable t-stat at Home Depot that says it's compatible with a multi-stage system. Will I just be able to swap over the wiring as above or...?
Thanks in advance, appreciate any and all responses (even if they're intended to make fun of my lack of knowledge )
burnt03 is offline   Reply With Quote
Two Wire 24V Thermostat to Digital Thermostat on Pellet Stove jrodtaclet Electrical 4 09-15-2009 06:37 PM
Thermostat from Manual to Digital trinamillersmit HVAC 5 07-02-2009 10:21 AM
High Rise Condo Thermostat Change omanalansan HVAC 8 10-24-2008 03:57 PM
condo thermostat change mason82 HVAC 2 09-12-2008 11:15 PM
