Thermostat Bunk? Set At 78 AC Still Running At 73 - HVAC - DIY Chatroom Home Improvement Forum
Old 07-02-2011, 08:29 PM   #1
Rewards Points: 184
Thermostat bunk? Set at 78 AC still running at 73
Is my thermostat bunk? I have it set at 78 and AC still running even though the temp is 73 inside now. If it turn the thermostat up to 80 it does top though.
Any ideas?
abefroman is offline   Reply With Quote
Old 07-02-2011, 09:31 PM   #2
Sounds like either old thermostat way out of calibration or it is installed on a outside wall or it is being effected by a heat source like a bulb, toaster etc...
Artco is offline   Reply With Quote
Old 07-03-2011, 01:17 PM   #3
Tizzer's Avatar
Rewards Points: 460
I just changed out my thermostat this a.m. as it was doing the same thing. It was an old mercury filled one.
I have my new one set at 79 and so far it kicks off at 79.
Tizzer is offline   Reply With Quote
Gas Furnace Won't Stay Running / Thermostat Set High To Start _scott HVAC 6 03-23-2011 07:27 PM
connecting a 4 wire SP thermostat to a 2 wire system wiichkin Electrical 4 08-15-2010 01:35 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 03:29 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
