Thermostat Blank - No Heat/ac - Fan Works - HVAC - DIY Chatroom Home Improvement Forum
Old 10-28-2010, 08:56 AM   #1
Thermostat blank - no heat/ac - fan works
So my thermostat screen went blank and the ac or heat do not turn on/work. However, if I switch the thermostat to "FAN" mode the fan still does turn on but still with a blank LCD screen - so hopefully this is a thermostat and not a hvac unit issue.
The thermostat is a newer Honeywell, the system is a heat pump. So far:
I checked the breaker box
checked wires in and out of the thermostat, air handler, and outdoor unit
I don't see any evidence of blown fuses or loose wires but I guess I need to pull off the side of the air handler and take a closer look. And probably do so electrical testing. But figured I'd post this in hopes someone with a similar problem could point me in the right direction - thanks!
snosurfa7 is offline   Reply With Quote
Old 10-28-2010, 09:32 AM   #2
Well I called Honeywell they said check the voltage between the R and G wires - if its between 24 and 30 the thermostat is bad - if not, contact a contractor (or more questions to come on this forum).
Did have a quick question anyway for now: I have a simple voltage tester but not a voltage meter - would something like this suffice?
http://www.northerntool.com/shop/too...ct_12496_12496
thanks
Old 10-28-2010, 09:44 AM   #3
fabrk8r
fabrk8r's Avatar
That tester will work fine.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 10-28-2010, 04:07 PM   #4
Some T-stat needs battery to run..
clocert is offline   Reply With Quote
Old 10-29-2010, 11:42 AM   #5
No battery on this one...fortunately, I have 26 volts from "R" to any other wire so it looks like hopefully just the thermostat is shot. Which is fine, those are pretty cheap and I can now upgrade to a programmable one...
Thanks for the help!
Trane XR90 blower works but no heat/ac ttrotta3 HVAC 1 11-08-2010 09:35 AM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 05:40 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
New Thermostat Acting Strangely stormchaser88 HVAC 2 06-18-2010 04:25 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
