Thermostat... - HVAC - DIY Chatroom Home Improvement Forum
Old 12-19-2010, 01:56 PM   #1
Thermostat...
So I wanted to get my parents something they could use. So I decided to get a new programmable thermostat. You all know where this is going, so its the old style setup.
Does anyone make a thermostat for old aquastats that is programmable?
I just need heat only, and high visibility would be a plus.
Thanks!
g60vwr is offline   Reply With Quote
Old 12-19-2010, 02:42 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 396
What do you mean by aquastats? Post a pic of the old one. Is it a gas or oil boiler?
Old 12-19-2010, 02:55 PM   #3
An old Tradesmen
Rewards Points: 8,184
probably need to get a battery operated one.
Old 12-19-2010, 06:05 PM   #4
Not my pic but
Old 12-19-2010, 06:57 PM   #5
An old Tradesmen
You need a battery operated one if you want to get them a set back thermostat.
Or a honeywell T87N if you just want anew thermostat for them.
connecting a 4 wire SP thermostat to a 2 wire system wiichkin Electrical 4 08-15-2010 01:35 PM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 05:40 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Two Wire 24V Thermostat to Digital Thermostat on Pellet Stove jrodtaclet Electrical 4 09-15-2009 05:37 PM
